Can't solve epg being 1 hr out??
  • q9pnu
    • Dec 2013
    • 6
    #31
    @algarveal why would you put epg default setting to satellite if we're trying to get XMLTV epg
    • dpm1980
      • Mar 2014
      • 20
      #32
      supp
      guys the problem is xmltv i believe its out because the clocks dont go forward in europe (or so i read in another froum)for another week or 2 so im thinking once that happens all will be ok just gotta wait it out
      • nobody
        • 25
        #33
        As someone has already said if you use the satellite to get your EPG all is well, but the XMLTV should also work and mine also is not working. I think this is why I have missed so many timer recordings.
        • mark9271
          • Jan 2014
          • 33
          #34
          hi 2 all,i don't know if this is any good or not but when i goto edit channel list in (MediaBox Editor Studio) i have noticed when u go into the receiver settings there is a time setting but it won't let me modify it, it is set at auto and you can't untick the box weather this info is of any use to someone.
          • Bladesman45
            • Jan 2014
            #35
            Mines all hunky dory. Changed to summer time on and did an EPG update. All spot on :-)
            • mark9271
              • Jan 2014
              • 33
              #36
              i tryed to no avil and with old epg
              • bbb_uk
                • 429
                #37
                Are you sure? The time may be correct but the xmltv epg itself is still out on mine.
                I'm using Sky1 as an example. At this moment football is on but according to my xmltv epg it's not on until 8.30pm (the xmltv epg still thinks it's an hour less). I tried this with UTC at 00:00 and GMT on. I also tried GMT off and UTC+01:00.
                However, I swap to satellite epg and no problems at all - everything is ok.
                So it looks like it's an XMLTV epg issue.
                • Bladesman45
                  • Jan 2014
                  #38
                  Scrap the last post. Positive it was showing all correct an hour or so ago. Although there is a possibility I read it wrong. Looks like I'm getting the same as you.
                  On ITV1 at the moment is Law And Order UK but my EPG telling me it doesn't start til 22.00. Oh well, back to the drawing board.
                  • bobhope1
                    • Nov 2010
                    • 85
                    #39
                    proper mind F""K, especially at my age.
                    • acoopermufc
                      • Apr 2014
                      • 6
                      #40
                      I'm getting exactly the same 1hr in front on XMLTV EPG Guide, hopefully it will sort it self out in the next couple of weeks.
                      • Hadron
                        • 2102
                        #41
                        Whoever posted that in the other forum is wrong.
                        All of Europe change their clocks at the same time:-
                        Daylight Saving Time and Daylight Saving Time map for countries and territories 2014-2015
                        However, other countries around the world change their clocks at slightly different times, but all of the northern hemisphere (apart from Mexico) have now changed.
                        The last Southern hemisphere countries to change will be on 27th April.
                        • genam
                          • Apr 2013
                          • 176
                          #42
                          i think mine is fine with the EPG side of things but when the box is on standby its own clock is 1hr ahead so starts any recordings too early.
                          I cleared the XMLTV files and did the latest update...both clocks were fine for about 2 minutes then went back to being 1hr out on the next reboot.
                          • az007
                            • Aug 2013
                            • 51
                            #43
                            all i did was got to local time settings in the menu and chnage summer time on. reboot done.
                            • bbb_uk
                              • 429
                              #44
                              That changes time but does not solve the epg problem via the xmltv (ie 7 day epg). The normal satellite epg (ie just now & next) is fine.
                              • Millzy
                                • 9
                                #45
                                Im getting the same also as posted from other people..
