i just did which got me the movies back but the last update file i could find online was the 20.07.2015 but i am new to this sort of thing so still dont know where to get update channel list from
The red stickies section at the top of the forum contains cwaite's and aj's newest channel lists, both do the same thing just the channel numbering is different. Just remember to unzip the downloaded list first and delete your old channel list off your box, full instructions @post 2 of aj's list here
AJ's UK Channel List
HD swapped.
OCD order (TLC, +1, +2 etc.)
Ordered so favourites aren't essential.
Duplicate & dead channels removed.
Favourites
Entertainment
Lifestyle
Movies
Sports
News
Documentaries
Kids
Music
Shopping
Religious
International
Gaming & Dating
Specialist
Adult
Regional
FTA
Thanks that helped but still missing sky one +1 and sky atlantci but now getting sky 1 and sky altantci + 1
And missing some of the box office channels, and sky sports 4,5 eurosports2
Sounds like a problem with your dish, lnb or cabling. But try this first, on your remote menu-channel edit, red button select 'all' and find and delete $ky atlantic. Next do a TP_list scan on freq 12148 27500 H instructions on how to do this can be found here
If some of your channels say scrambled after a frequency change's the easiest way to fix them.....
If you don't know how to update the box with Aj's or Sattv5 channel list (which are the best i have found so far ) via usb then follow the info below.....
You need to find out which transponder the channel has moved to..... Plz
$ky Atlantic should be now at the end of all your channels.
using an official receiver with these cheap tat receivers is a big no-no, switch off the official receiver completely and by that i mean unplug it then try those channels again.
