Openbox S9 HD PVR Linux Satellite Box
  • Jo-Jo
    • 511
    #346
    i too have a pannasonic tv and no probs via hdmi with my s9 mrs cant use it tho i need to sort some sort of channel structure on it
    • thezafiraman
      • Aug 2008
      • 74
      #347
      Originally Posted by thezafiraman View Post
      Thnaks for the input Hoolley.Is this what I should be looking for?
      here you go
      Yes indeed. You might need to add some channels manually because their frequency would have changed. I find king of sat handy for finding frequencies.
      Thanks Hooley.second box arived today and set up and running in less than 10 minutes.Used the channel list you suggested.I have not been thru all the channles, so don't know whats missing.No doubt will soon find out.Thanks everyone for your input on here,very handy for novices.
      • thezafiraman
        • Aug 2008
        • 74
        #348
        Hi Guys
        Is it realy a good machine? they are for sale on loads of websites not more then ?90.00 each
        A sincere opinion guys
        Regards
        Moreira2010
        If you are still thinking of buying this box,go for it.A lot easier to setup than a Dreambox.Picture through Scart is good and through HD is brilliant.Read the posts in this forum and you will have all the info you need to have your box running in no time.
        • goliung
          • Oct 2010
          #349
          OPENBOX S9 HD PVR RECEIVER
          ANYONE KNEW HOW TO ENTER THE BISS KEY MANUALLY FOR MY NEW RECEIVER MODEL OPENBOX S9 HD PVR ?
          • goliung
            • Oct 2010
            #350
            I AM USING OPENBOX S9 HD PVR RECEIVER.
            ANYONE CAN GUIDE ME OF HOW TO ENTER
            THE BISS KEY MANUALLY ?
            • fabmazz74
              • Nov 2010
              • 9
              #351
              scambled
              MY box well not just mine on sly it most of the chann;s keep cutting out.I've rebooting it rebooting adsl and nothing. Any one having the same probs?.P.S Same with spanish, german, french, the spanish only sd works the french woks 4 a while,and the germen even the sd dont work well some of them.They r fine on my TM 500.As any one had or got the same probs?????????????Any help would be great.
              • hooley
                • 470
                #352
                Sounds like you're server is a bit flaky. My German and Italian channels work fine
                • nowuckinfurries
                  • Aug 2009
                  • 111
                  #353
                  Please Remember that using CAPITALS in Forums is considered to be SHOUTING.
                  • fanaticwear
                    #354
                    Hi guys
                    After trying o install 2 clines by usb rebooted the box but it wont open!
                    Styt appear on the box screen. Any help please
                    • nowuckinfurries
                      • Aug 2009
                      • 111
                      #355
                      Have you made the lines active under cfg Management before you re-booted?
                      • Timmaa
                        • 88
                        #356
                        Also make sure your network settings are correct.
                        • binary
                          • Mar 2009
                          • 121
                          #357
                          Hi all, Just had a similar problem in updating checked cam file before installing its ok. Ticked file after loading re-checked cam on box no files showing also set DHCP to on also used a new stick for upload..any suggestions
                          • Timmaa
                            • 88
                            #358
                            Are you saying that the config line is no longer there when you go into the manager? It should definitely stay there after you load it, activate and then reboot the box. Have you done a factory reset instead of rebooting? Maybe the box had 'a moment' - reload your config and activate. Then reboot the box and cross your fingers!
                            • nikkz
                              • Dec 2010
                              • 5
                              #359
                              ello everyone im new to the forum so be gentle.ive just got the openbox hd but so far i dont rate it as i cant even get the cccam to work ive put the firmware on but cant seem to up load my cfg.file or find any cccam versons installed in the firmware.
                              • binary
                                • Mar 2009
                                • 121
                                #360
                                Hi timmaa, reset and rebooted no joy, the problem may be in the CCcam client setup where file update by USB shows
                                now reading... CCcam.cfg
                                CCcam.cfg not found!
                                read all finished!
                                although it does look as though it is loading..and there is a unzipped file on the stick
                                thanks for your attention
