Originally Posted by thezafiraman View Post
Thnaks for the input Hoolley.Is this what I should be looking for?
here you go
Yes indeed. You might need to add some channels manually because their frequency would have changed. I find king of sat handy for finding frequencies.
Thanks Hooley.second box arived today and set up and running in less than 10 minutes.Used the channel list you suggested.I have not been thru all the channles, so don't know whats missing.No doubt will soon find out.Thanks everyone for your input on here,very handy for novices.
Hi Guys
Is it realy a good machine? they are for sale on loads of websites not more then ?90.00 each
A sincere opinion guys
Regards
Moreira2010
If you are still thinking of buying this box,go for it.A lot easier to setup than a Dreambox.Picture through Scart is good and through HD is brilliant.Read the posts in this forum and you will have all the info you need to have your box running in no time.
MY box well not just mine on sly it most of the chann;s keep cutting out.I've rebooting it rebooting adsl and nothing. Any one having the same probs?.P.S Same with spanish, german, french, the spanish only sd works the french woks 4 a while,and the germen even the sd dont work well some of them.They r fine on my TM 500.As any one had or got the same probs?????????????Any help would be great.
Reason: added
Hi all, Just had a similar problem in updating checked cam file before installing its ok. Ticked file after loading re-checked cam on box no files showing also set DHCP to on also used a new stick for upload..any suggestions
Are you saying that the config line is no longer there when you go into the manager? It should definitely stay there after you load it, activate and then reboot the box. Have you done a factory reset instead of rebooting? Maybe the box had 'a moment' - reload your config and activate. Then reboot the box and cross your fingers!
ello everyone im new to the forum so be gentle.ive just got the openbox hd but so far i dont rate it as i cant even get the cccam to work ive put the firmware on but cant seem to up load my cfg.file or find any cccam versons installed in the firmware.
Hi timmaa, reset and rebooted no joy, the problem may be in the CCcam client setup where file update by USB shows now reading... CCcam.cfg CCcam.cfg not found! read all finished!
although it does look as though it is loading..and there is a unzipped file on the stick
thanks for your attention
