Openbox S9 HD PVR Linux Satellite Box
  • Adam_UK
    • 464
    #481
    Originally posted by hooley
    Try this: Menu - Network Local setting - C**am plug setting - Manage config files - C**am.cfg
    You will see your info then.
    Thanks, but this shows the servers online that you are connected to. What I was on about is on TMN & DM when you have several lines from several provides you can see which server you are connected to on a specifc channel, it looks you can't do this with Openbox. I just got the box yesterday and had quick play with it.
    • choozay
      • 23
      #482
      Think i fixed the issue, i turned on DHCP and did a preset scan with internet on..
      Now how to you install the favorite.abs file??
      Do you install it first and then scan for channels or install channels then the file?
      • mept1
        • 346
        #483
        i posted a fav installation here http://www.digital-kaos.co.uk/forums...tml#post921095
        • Rlaffey
          • Dec 2010
          Originally posted by eattheliving
          ok guy's need some guidance now please.
          when i do a scan on 28.2e all the TP's on vertical are showing as failed and end result is that I'm not seeing any of the music channels on the final prog list.... any ideas please
          cheers
          uploaded the 28.2 channel list and got (from what i can see) all the channels listed as required but now on quite a few of them I'm getting no signal?? help pls
          Sorry for the late response but I was having the same issue. I had a sly HD box and Freesat tv on the same lnb (octo lnb). I disconnected both the TV and sly box. When I did that openbox picked up all the channels no problem.
          Sly Sp3 was one of my problem channels so I kept it on that, plugged in the TV coax, no issues, plugged in line 1 on the sly box, no issues, plugged in line 2 on the sly box, no signal on openbox.
          Connecting both inputs on the sly box seems to be the problem and I lost about 50% of my HD channels.
          So......I bought an inline amp on ebay, now I can connect everything okay and get a fairly good signal on the openbox (90% sig, 75% quality) but get a bit of pixelation on some of the hd channels. My cable run is quite long (about 60 feet).
          Does anyone else have the stalling/pixelation issues? they only occur on HD channels.
          May be worth a try for you.
          • hooley
            • 470
            #485
            I get you now, no i dont think there is a way to see what you're looking for
            • choozay
              • 23
              #486
              Cheers mept, i manage to get it dne!! I took da plunge an jus uploaded the fav file!!
              I was havin issue with my sky news( rebooting) i have nw deleted it!! Wats the best way to get a working sky news channel??
              • mept1
                • 346
                #487
                i just added the hd sky news,....the sd one causes the rebooting.
                • choozay
                  • 23
                  #488
                  Aaahhhh!! Will give that a twirl once i gt home..
                  If this box works den its pretty awesome!!
                  • mept1
                    • 346
                    #489
                    yip,...best budget hd box i,v come across,...perfer it over the vu duo(personal opinion of course).
                    • choozay
                      • 23
                      #490
                      The only downside i see is da fact u cant access it ova the web and da reboot issue! But im sure as the box becomes more commercial the software support will improve!!
                      • mept1
                        • 346
                        #491
                        agreed but for less than ?100,..well worth it,.. but the reboot issue has been sorted,..i uploaded a list with all the rebooting channels removed,but maybe except that sd skynews channel.
                        • choozay
                          • 23
                          #492
                          Yeah im pretty sure i downloaded your list.. And your right it seems to be the sd sky news!!
                          Gonna go config my mates s9 box
                          Could you plz post a firmware and fav channel files here plz?? Took me ages to search for but i aint saved em
                          • mept1
                            • 346
                            #493
                            just take a dump by usb from your box.
                            • choozay
                              • 23
                              #494
                              Oh yeah!! Lol
                              Wat order would i do it??
                              Install update..install fav channels..scan channels??
                              • choozay
                                • 23
                                #495
                                When askin hw i would do it, im refering to installing it on my friends openbox!
