Hi, i downloaded the firmware for the s9 today, got it all up and running but i can't get onto the option to do a scan for more channels, the option isnt lit up as it use to be. Any idea what this could be.
openbox s9
Sorted it now, after reading about i found someone else had the same problem. Had to go into settings and select the satellites i wanted to scan then all the options lit up.
If it isn't broke, don't try fixin it..!!!
Glad you got sorted :0)
Does anyone have an updated channel list for the S9 tuning the latest firmware
If so can you please post / upload it in this thread
Many Thanks
KevReceivers----------OPENBOX X3
Skybox M3DM528 - PliJadeDM500s - PliJadeTechnomate TM500 - UR--------------------------------------------------------
If you like my posts press the "Thanks" button to show your appreciationComment
here's the one im using now i downloaded it on 4/7 and its working fine.Attached FilesLast edited by darcu5; 13 July, 2011, 11:47.If it isn't broke, don't try fixin it..!!!
This is the same list but i removed the foreign & advertising channels, added a few more in music favs, and organised other favs into some sort of order. (you might want to rename the fav channels but you can do that on the box once installed)Attached FilesIf it isn't broke, don't try fixin it..!!!
Is that a serious question?
If you have a HDTV s9. Simple to setup. Add Cline via remote or USB.it's idiot proof. Well except folk dumping new firmware on their clones.
Word of advice there is no need to update the firmware everComment
I've not done an update for a while so here it is.
This is a complete up to date list for 28.2 (as of 03/08/11). All channels have been sorted, organized, and named and all are confirmed working. All you need to do is set your regional BBC/ITV channels. I have spent a good day on this so hope people find it useful.
1. Entertainment
2. Movies
3. Sport
4. Music
5. Discovery
6. Kids
7. Lifestyle
8. News
9. PPV
10. Shopping
11. Adult
12. Misc
All working nicely with the latest firmware (31/7/11) that I've included. Make sure if you are using older or different firmware that it supports more than 8 favorites.
** remember if your updating your firmware, standard practice is to backup/dump your original, then factory reset, then upgrade.Comment
Hi ziggycat
Is the firmware you described as skybox s9 OK for the openbox. I have confirmed mine is not a clone.
Many thanksComment
