Dreambox streaming to internet,it was never easy like this
  • mikmoz
    • 63
    #406
    well a big thank you to mfaraj57 and all who have posted here i am up and running streaming with this great bit of software.took a bit of time searching through all the posts but found all the info here.it works really well and is well worth persevering till you get it right.and i am a complete novice so if i can do it anyone can.cheers
    • nabat
      • Mar 2010
      • 10
      #407
      Continous buffering problem
      Hi mfaraj57,
      Have managed to get Tunisia web receiver version 5.0.2 partly working from my office while streaming from home via web streamer/player version 6.0.0f.
      I have two problems:-
      1/ web receiver keeps on buffering very frequently. It starts buffering unti it reaches 60 % buffering then it works for a couple of seconds then it starts buffering again until it reaches 50 % and then it works for 2-3 seconds, then starts buffering again and so on> This makes watching from office nearly imposibile. Please help.
      2/ There is no voice or sound in office end.
      At home I have vlc .99 installed.
      At home A have 2 mega adsl speed ,while in office I have 1 meg adsl speed.
      3/ 1234 +5678 TCP ports are opened at home computer
      4/ 1234 +5678 TCP ports are opened at office computer.
      5/ dyndns address is updated at home.
      6/ Web receiver setting in office is:-
      A/ Server DNS address :dyndns address same as that of home computer
      B/ Server streaming port : 1234
      C/ Dreambox port : 80
      Kindly urgently help me with this great application
      Best regards
      • tkm18
        • Aug 2009
        • 158
        #408
        Originally posted by nabat
        Hi mfaraj57,
        Best regards
        I would imagine the buffering is caused by a poor upload speed.
        • mfaraj57
          • 557
          #409
          Hi Nabat
          be sure that the problem is not systemic as example from sound card or drivers or others
          test windows media player with and sound file
          if sound coming from wmp then try to install ac3filter(google)
          if this doesnot fix the problem then reinstall the program codec by installing the new version of the program present in the link in the first post in this subject 6.0.1
          if this doesnot fix the probelm the issue mostly from the image in the dream doesnot streaming sound flashing the dream with new version pli image will fix the probelm
          regards
          • nabat
            • Mar 2010
            • 10
            #410
            Originally posted by mfaraj57
            Hi Nabat
            regards
            Hi mfaraj57,
            Appreciate your quick response.
            1/ sound problem resolved thanks.
            2/ My biggest remaining problem is that the web receiver keeps on buffering very frequently. It starts buffering unti it reaches 60 % buffering then it works for a couple of seconds then it starts buffering again until it reaches 50 % and then it works for 2-3 seconds, then starts buffering again and so on> This makes watching from office nearly imposibile. Please help.
            • mfaraj57
              • 557
              #411
              what,s your upload speed
              you can measure it at speedtest.net
              according your upload speed choose appropriate option from settings
              if you do not mind post private message with your dns address to test(this is for your and i respect your decision if you will not send)
              • nabat
                • Mar 2010
                • 10
                #412
                Hi ,
                Again highly appreciate your prompt response.
                Re upload rates these are the results obtained now from "speedtest.net"
                Download Rates / Kilo bits/sec
                1739
                1750
                1771
                1700
                1710
                1520
                1815
                Upload Rates in Kilo bits/sec
                70
                152
                181
                112
                122
                91
                110
                I was using the High adsl profile
                access MMsh
                encapsulation:asf/wmv
                vcodec: WMV2
                vbitrate:1024
                v scale :0.5
                a codec: mp3
                abitrate 32
                ascale:1.0
                Please advise all settings I should use.
                Best regards
                • mfaraj57
                  • 557
                  #413
                  according to your reading seem to have 2 mb internet speed,and low actual upload speed around 100 kb/s
                  this is lowe speed and you should try low upload speed profile
                  • tkm18
                    • Aug 2009
                    • 158
                    #414
                    @ mfaraj57
                    Couple of quick things.
                    1st, whats a decent upload speed to achieve good results when streaming online and to JustinTV, i have both running but the results are poor.
                    2nd, when setting the timer, is there was to set the channel you wish to record rather than set the timer with the channel running?
                    I can record and i know ti changes to the channel when the timer starts, but couldnt see a way to just select a channel to record.
                    Thanks.
                    • thered
                      • Aug 2008
                      • 4915
                      #415
                      hi mfaraj57 is this now working ok on a DM7025 or does it still have issues thanks
                      • nabat
                        • Mar 2010
                        • 10
                        #416
                        Hi mfaraj57
                        I have finally succeeded to get the receiver 5.02 working after I applied the low upload speed profile.
                        Thank you for your help.
                        The quality of the image on the receiving end is off course not the best but what shall we do -- its better than nothing.
                        Its a pity that in spite of having a 2 mega speed adsl line I have
                        less than 200 kilo bit/sec actual rate of upload. There is nothing I can do about it. Will try to read how to improve pc upload rate.Any ideas?
                        I have two questions for you please:
                        1/ What are the best "Advance" settings for Low speed upload profile I.e :
                        Encpsulation
                        vcodec
                        vbitrate
                        vscale
                        acodec
                        abitrate
                        ascale
                        2/ Which player/streamer version do you recommend to be used with receiver version 5.0.2. Is it Tunisia-sat Dreambox player and web streamer6.0.0F or Tunisia-sat Dreambox player and web streamer6.0.1 and why.
                        Again my best regards and appreciation for your great acheivement
                        • mfaraj57
                          • 557
                          #417
                          works on dm800 and dm8000 so should work on dm2025,try and tell me
                          • nabat
                            • Mar 2010
                            • 10
                            #418
                            hi mfaraj57
                            Any response to my last post please.
                            TIA
                            • mfaraj57
                              • 557
                              #419
                              Hi Nabat
                              web receiver program works with any version of streamer best is latest 6.0.1
                              regarding the best selected advanced for low speed upload
                              encapsulation
                              asf/wmv
                              access mms
                              vbtirate 200-400
                              vscale .25 or .5
                              vcodec wmv2
                              this same as preset low adsl low profile
                              even with this low speed you can stream radio channels efficiently,you can ask your internet provider to increase upload speed
                              regards
                              • nabat
                                • Mar 2010
                                • 10
                                #420
                                Hi Nabat
                                encapsulation
                                asf/wmv
                                access mms
                                vbtirate 200-400
                                vscale .25 or .5
                                vcodec wmv2
                                regards
                                Thanks a lot and best regards
