BackUp of Dreambox Image with all of its Plug Ins and Cam EMUs
  • NewBirth2010
    • 56
    Is it possible? With all of its plug-ins and add ons?
  • MetalKettle
    V.I.P.P.T. Member
    • 797
    Yes... you can do it via dreamup, or via a telnet script.
    XBMC/KODI Developer
    • NewBirth2010
      • 56
      Thanks MetalKettle
      But, I think DreamUp is for flashing an image. I need to back it up !
      Michael
      • MetalKettle
        V.I.P.P.T. Member
        • 797
        Thanks MetalKettle
        Michael
        DreamUp also has a backup button !
        XBMC/KODI Developer
        • .: JaCkPoT :.
          Retired Sat TV Addict
          • 5611
          After you connect you will see a backup button on she right panel half way up on dreamup.
          ___________________
          In the good old days, I had
          DM800s HD
          Openbox S10
          TM500
          DM500s
          90cm FortecStar dish
          Maxx 110cm Dish
          Technomate 2300 Motors
          • NewBirth2010
            • 56
            Thanks guys. I have tried with Telnet, but had many problems.
            When I type in telnet:
            cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
            I get the error:
            -sh: eraseall: not found
            I will probably give up and use the DreamUp method instead !
            Michael J
            • wk210003
              • Aug 2009
              revice the syntax again
              • opsmonkey
                • 5379
                Newbirth you just need to do the following..
                Go to the RUN command in windows..
                type telnet 192.168.x.x (replace the x with the rest of your ip address)
                log in with user / pass
                type..
                cat /dev/mtd/3 > /tmp/backup.img
                then use your FTP prog to copy the backup.img to your pc hard drive..
                the code you were using.
                is to flash an image not the code to back up
                • NewBirth2010
                  • 56
                  No Guys. I did everything using the code
                  In telnet I get:
                  My dreambox is the DB 800 HD. I think this is not working for DM 800 because it does not use .img images
                  Any ideas?
                  • westkill
                    • 2378
                    In telnet I get:
                    Any ideas?
                    what you trying to do is for enigma1 images, dm800 is enigma2
                    these telnet and dreamup will not backup enigma2 images
                    if using barryallen theres an option to backup image of everything in image
                    or save your settings via software manager to hdd or usb
                    then every time you reflash it will pick up your settings channels/bouquets/timers/ip setting/not the cams or plugins
                    • pknudam
                      • Jun 2009
                      dual unlooper
                      how to flash dual unlooper
                      • Curious123
                        • 2591
                        I do not have a dm800 my box is dm600 but this plugin work fine for me. Try this plugin on your box and see what happens;
                        • NewBirth2010
                          • 56
                          I tried it Curious123.
                          It does not work in DB800.
                          Thanks Anyway.
                          I lost my null modem serial cable, But I think it is possible to back the DB 800 HD up, using DreamUp.
                          Thanks.
                          M.
                          • jicube
                            • Sep 2009
                            • 4
                            if i make a back up using dream up cuold i flash this to another box and receive all channells etc and not have to set up the box
                            • mfaraj57
                              • 557
                              Hi
                              Dream up will not back up dm800 image
                              the only way by using barry allen either from dream or through dcc
                              You may succeed in taking backup by dream up or by internet explorer in setup mode but no garrante you can restore successfully
