SGTFlipFlop SKYUK Bouquets - Updated Regularly
Going to sound thick here, before I used to drag & drop to update my regionals, now if I do that it seems to screw the Sky numbering.
Do I need to edit my regionals before I copy them into the Sky numbered bouquet?Leave a comment:
so your not using marwensat 2.4 as u said u your post
didnt think pli needed any settings changed
havnt got a pli image to check only use commando on 500s now . loads SGTFlipFlop channels for u every nightLast edited by smirnoff_rules; 5 September, 2012, 21:51.Leave a comment:
sorry my image is pli jadeLeave a comment:
Menu => System => Customize section of the user experience, "expert" as a change. Yet at the same place;
(Menu => System => Customize section) Enable the use of multi-bouquet "yes" as a change. press green button to save the changes (OK) is pressed.Leave a comment:
i cant seem to find advanced on DBE and also cant find multi bouquets on my dreambox the image im using is marwensat 2.4Did you do this before starting?
in DBE options > advanced > make sure all boxes are ticked especially multi bouquets
On Dreambox make sure Multi Bouquets are ticked (Menu>Setup>System>Customize>Expert>Enable Multi Bouquets-YES)
The text in bold needs to be done before you open the bouquets in DBE, ThanksLeave a comment:
Hi Sarge
I hope you're well. Just a quick question in connection to your excellent bouquets. With E1, the last 3-4 bouquets folder Interactive folder is classed as Data instead of TV, resulting in no picture.
I've changed it in DBE to TV but still no luck. Any idea how this folder can be sorted?
CheersLeave a comment:
sorry, i tried to reply and made a hash of it. i'm new to the site so apologies.
with reference to the power supply cord, i also recieved a 2 pin plug but i replaced the lead with the old lead from my sky+ box.
it works fine.Leave a comment:
just moved British Eurosport 2 HD & TCM HD into HD Channels Thanks SGT for sorting Star plus HD out this timeLeave a comment:
Hi thanks for the new update, never having had a sky box I can see what people are talking about with the sky numbering I think the old way is more logical but you now have the choice.Leave a comment:
Here is the latest update
DreamboxEdit 5.0.2.0 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 4th September 2012
Bouquet Updates
Okay here we go, After a lot of people asking I have added the sky numbering to the Enigma2 bouquet. 106 - Sky One, 401 - Sky Sports 1 etc these channels are situated in the SGTFlipFlop folder up top, Now if you don't want the Sky Numbering just delete this folder and it will turn back to Oldskool bouquet set-up.
Before these Numbering bouquets work you need to make some changes to DBE and your Enigma2 box
For Regional changes you will now need to do these in SGTFlipFlop & Entertainment bouquets now.
317 - TCM HD (New Channel)
341 - TCM (SD Moved)
411 - British Eurosport 2 HD (New Channel)
412 - British Eurosport 2 (SD Moved)
800 - Set Max Renamed to Sony Max
814 - Channel 'S' Renamed to CHSTV
816 - SAB TV Renamed to Sony SAB
831 - Rishtey (New Channel)
Removed Channels
ITV1 Granada HD
Picons
Updated newest channels
** Dumped Multi Bouquet, Don't Use My Dish No More Pointless Updating, Check Out Catseye settings, Excellent **
These bouquets are positioned identical to the Sky Box, Enjoy a neat up to date bouquet.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
no problem since i changed it about week or so could be the some ppl d/loading your bouquets at later stageLeave a comment:
Leave a comment:
