SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • SGTFlipFlop
    replied
    Originally posted by Hackdroid
    star plus hd doesnt seem to work anyone know the right parameters for it?
    No idea why it keeps changing
    Open my Bouquets in DBE
    Find Star Plus HD (Right click on it Edit Transponder Data)
    Change System from DVB-S2 to DVB-S (Click Save)
    Save Bouquet
    Send to box, All fixed
    Leave a comment:
  • Hackdroid
    replied
    Leave a comment:
  • adiraian
    replied
    Thanks mate...how about if i have multi sat? it seems it deleted other 2
    Leave a comment:
  • meggiedude
    replied
    Originally posted by SGTFlipFlop
    Cheers Dude.
    Thats the ticket
    Leave a comment:
  • SGTFlipFlop
    replied
    Here is a screengrab of the settings
    Leave a comment:
  • SGTFlipFlop
    replied
    Download this :- http://www.sgtflipflop.ukfsn.org/?file_id=18
    Leave a comment:
  • meggiedude
    replied
    Okay to fix this is DBE
    Open Bouquet
    Right Click on C4 Para 1 HD (Edit Transponder Data)
    Change Symbolrate to 29500,
    Change FEC to 3/4
    Change System to DVB-S2,
    Change Modulation to QPSK
    Change Rolloff to 0.25
    Change Pilot to Auto
    Save and send bouquet to device, all fixed
    Thanks.
    I can see and change the Symbolrate and FEC, but not the rest.
    Is there some additional settings/options I need to enable??
    BTW Help about in DBE gives me 3.0.0.0
    Cheers,
    MD
    Leave a comment:
  • SGTFlipFlop
    replied
    Originally posted by meggiedude
    Lo there SGTFlipFlop
    Loaded the latest Bouquet - Thanks. Great job.
    Small point - but Issue with C4 Param1 HD and kids are bleating about it. Looks to be set wrong.
    Equiv SD channel works OK.
    Had a dig around and should 27500 be 29500??
    Cheers,
    MD
    Open Bouquet
    Change FEC to 3/4
    Leave a comment:
  • SGTFlipFlop
    replied
    Will look now, They where working when I loaded them up the other day must have changed before launch
    Leave a comment:
  • meggiedude
    replied
    Cheers,
    MD
    Leave a comment:
  • SGTFlipFlop
    replied
    Originally posted by romman
    Hi sgt
    301 takes me to channel 588 (gospel channel)
    401 takes me to channel 729 (sky box office)
    cheers
    Did you do this before starting?
    in DBE options > advanced > make sure all boxes are ticked especially multi bouquets
    On Dreambox make sure Multi Bouquets are ticked (Menu>Setup>System>Customize>Expert>Enable Multi Bouquets-YES)
    The text in bold needs to be done before you open the bouquets in DBE, Thanks
    Leave a comment:
  • Mee?kat
    replied
    Here is the full version, Just it a test and post feedback
    Remember you need to edit regional channels in SGTFlipFlop & Entertainment folders first
    Hi sgt
    cheers
    Leave a comment:
  • SGTFlipFlop
    replied
    Fantastic idea to number the channels sgt...hats off and thanks for all your hard work as i personally really appreciate it.
    Sky movies premiere hd is channel 771... is that the normal channel start for sky..sky sports 1 hd is 811.
    is that the normal sky numbering or have i missed something..
    thanks again
    They are onlt numbered in the first bouquet, 301 will get you Sky Movies Premier HD
    and 401 will get you Sky Sports 1 HD
    ta
    Leave a comment:
  • Mee?kat
    replied
    thanks again
    Leave a comment:
  • SGTFlipFlop
    replied
    Originally posted by lincsat
    There is now an AutoBouquet plugin that sorts the channels from the data stream and gives the exact Sky numbering and regional channels for your area. It will likely make some channel lists obsolete but personally I don't like Sky's channel order, too jumbled for me
    I tried Auto Bouquet, Quite good but you still need to scan then do the update takes about 1hour all in, Quite time consuming, Great idea tho
    Leave a comment:
