SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • vmd1916
    • 109
    #136
    hello sgt i used updates a few times, thanks
    just a question i update but tv3 never works any ideas?everything else is great,,
    • SGTFlipFlop
      • Sep 2009
      • 1002
      #137
      I'll look at that later today mate
      • junger
        • 200
        #138
        Any chance of a north west bouquet please?
        If only I had more time that I could waste
        • smirnoff_rules
          • 8603
          #139
          ~~~~ me m8 u only have to edit 3 channels
          • opsmonkey
            • 5379
            #140
            some people mate.... ffs sake lad.. do it yourself with Dreambox edit... you wont get titty fed everything
            • junger
              • 200
              #141
              Thanks guys, done it
              • etch
                • 70
                #142
                Hey SGT,
                Any news with regard to Sky Anytime? I see that bouquets and picons have been posted on this forum by someone else that include sky anytime?
                Also, do you have any picons for 19.2e and 13e? If not, where can you recommend i get them from?
                Sorry for all the questions!
                • SGTFlipFlop
                  • Sep 2009
                  • 1002
                  #143
                  Actually forgot about Sky Anytime channels, If I get time later I'll update my post
                  • smirnoff_rules
                    • 8603
                    #144
                    why your around , l added movies on all sats folder ,, wondered if people can add to it or remove crap ones ,, would be a nice touch to your bouquets
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      #145
                      Just looking at TV3, What seems to be your problem with it?
                      I can't get it to work because I need an Irish sub to view it, Is that the reason you cant get it?
                      • SGTFlipFlop
                        • Sep 2009
                        • 1002
                        #146
                        Here is the latest update
                        DreamboxEdit 4.0.1.0 Used (Recommended) Guide Here
                        Updates: 21st November 2010
                        DM800 Bouquet Only
                        Hajj TV Renamed To UCTV
                        Sky Anytime (3 Channels)
                        Removed Channels
                        None
                        Picons
                        Updated new channels
                        Finally got round to releasing Sky Anytime Info after knowing about it quite a while, There is 5 channels but only 3 show stuff all the time so I haven't included the other 2 for now, If anyone knows how to find out the EPG for these let me know
                        ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                        Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
                        Use any FTP client, DCC for example, to transfer the picon directory
                        to one of the following paths on Flash, HDD, CF or USB respectively:
                        /usr/share/enigma2
                        NOT recommended, because of limited capacity of the flash memory
                        /media/hdd
                        HDD will keep running indefinitely and may affect image performance
                        /media/cf
                        Recommended if CF available and successfully mounted (8000/800)
                        /media/usb
                        Recommended if USB available and successfully mounted (8000/800)
                        Picon will display immediately on zapping, no further setup required!
                        Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
                        Please keep this thread clean, Use the Thanks button rather than posting on the thread
                        • mtj111
                          • Feb 2010
                          I have an Irish sub and can confirm TV3 works fine.
                          Thanks for the Anytime channels sgt, will be nice to maybe catch some things before they officially air without ads or logos! If you could add the other 2 channels next time that would be great.... I don't mind that they don't broadcast all the time.
                          • SGTFlipFlop
                            • Sep 2009
                            • 1002
                            #148
                            Sure
                            • vmd1916
                              • 109
                              #149
                              hello im not sure ,but i see mtj111 has it so must be my end , apologies ,and thanks you for your great work its apreciated by all..
                              • andy91
                                • Aug 2010
                                • 3583
                                #150
                                Can someone tell me if the Itv Hd channels 234 are working or is it just mine that dont work or are they just testing them at the moment.
                                Many thanks Andy.
