Here is the latest update
DreamboxEdit 4.0.1.0 Used (Recommended) Guide Here
Updates: 26th November 2010
DM800 Bouquet Only
Community Channel (Frequency Change)
Nat Geographic Channel (Frequency Change)
Nat Geo Wild (Frequency Change)
VOT Radio Renamed RCR Radio
Showcase TV 2 (Frequency Change)
Sky Sports 1 (Frequency Change)
Sky Sports 3 (Frequency Change)
Sky Sports 4 (Frequency Change)
Sky1 Ireland (Frequency Change)
Sky2 (Frequency Change)
Sky3 (Frequency Change)
WTF (New Channel)
Removed Channels
None
Picons
Updated new channels
Finally got round to releasing Sky Anytime Info after knowing about it quite a while, There is 5 channels but only 3 show stuff all the time so I haven't included the other 2 for now, If anyone knows how to find out the EPG for these let me know
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the thread
DM800 Bouquet Only
WTF (New Channel)
Removed Channels
None
Picons
Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
