SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • snaps
    • Dec 2010
    • 24
    #196
    Thanks guys, Sgt Flip Flops are the top bouquets!! Im looking for E2 (DM800) and E1(DM500) motor bouquets.
    • RuberDuck
      • 1724
      #197
      well SGT no longer makes motorised bouquets so you'll have to look else where for those.
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #198
        Here is the latest update
        DreamboxEdit 4.0.1.1 Used (Recommended) Guide Here
        Updates: 9th January 2011
        Bouquet Updates
        Updated all Necessary Changes over the last month
        All channels there and accounted for
        Removed Channels
        All Bravo Channels
        Picons
        Changed a few older Picons
        ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
        Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
        Use any FTP client, DCC for example, to transfer the picon directory
        to one of the following paths on Flash, HDD, CF or USB respectively:
        /usr/share/enigma2
        NOT recommended, because of limited capacity of the flash memory
        /media/hdd
        HDD will keep running indefinitely and may affect image performance
        /media/cf
        Recommended if CF available and successfully mounted (8000/800)
        /media/usb
        Recommended if USB available and successfully mounted (8000/800)
        Picon will display immediately on zapping, no further setup required!
        Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
        Please keep this thread clean, Use the Thanks button rather than posting on the thread
        • smirnoff_rules
          • 8603
          #199
          great stuff but wot happened to your allsat ones , there were great too
          • SGTFlipFlop
            • Sep 2009
            • 1002
            #200
            No way of checking them, The person I got access from did a bunk and left me high and dry, So cannot check if the channels work or not
            • billy2
              • 1381
              #201
              not the only 1 m8, thanks for your time with the bouquets saves alot of time cheers
              please press the little red THANKS tab
              if I helped if not press the green tab to tell me to f**Koff
              • smirnoff_rules
                • 8603
                #202
                anyone know how to add the sports folder from this one to sgtfipflop's one above , l have tried opening dreamedit twice but cant drag into each other ?
                cheers
                • SGTFlipFlop
                  • Sep 2009
                  • 1002
                  #203
                  Use the import feature up top, and Choose Import User Bouquet Files
                  • SGTFlipFlop
                    • Sep 2009
                    • 1002
                    #204
                    DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
                    Updates: 11th January 2011
                    Bouquet Updates
                    ITV1 +1 Channels added into there relevant Bouquets (Enabled from 8pm tonight)
                    Removed Channels
                    Picons
                    No Picon changes where made
                    /usr/share/enigma2
                    /media/hdd
                    /media/cf
                    /media/usb
                    • mikiec
                      • Aug 2009
                      • 10
                      #205
                      Thanks for the list - it's just what I'm looking for.
                      Only problem I'm having is that all the HD channels are coming up with Tuner Failed, with the exception of BBC1 HD, BBC HD and ITV1 HD (all the FTA channels).
                      I've got access to those channels and they all worked before I had to rebuild my box. I've also done a scan of 19.2e and all the HD channels work fine including the pay ones.
                      I'm doing a blind scan of 28.2e now to see if I can get any to work after that and I'll let you know.
                      Cheers!
                      • mikiec
                        • Aug 2009
                        • 10
                        #206
                        I've done two blind scans and I'm still getting nowhere. I've tried a new CCCam as I was using the one that came with the image which is a couple of years old now - still no luck.
                        I'm going to try deleting all the channels and see if that works.
                        Any ideas would be really helpful.
                        My setup is:-
                        DM800 (clone)
                        Nabilosat BlackHole v0.11 (for clones)
                        • nr24103
                          • 26
                          #207
                          My setup is:-
                          DM800 (clone)
                          i had this problem go into tuner set up.click on advanced. go down the list to where it says usals and click to yes. press ok. and rescan now you should have all hd channels hope this helps you m8
                          • mikiec
                            • Aug 2009
                            • 10
                            #208
                            Cheers! I'd already set it to positioner (no USALS option on mine, maybe because it's Blackhole) and I scanned it again but set it to clear before scan, which did the trick.
                            Anyone know where I can get channel lists for other sats?
                            • SGTFlipFlop
                              • Sep 2009
                              • 1002
                              #209
                              If scanning you always need to set it too clear before scan
                              • nobby
                                • 205
                                #210
                                will these be ok for dm500s bouquets
