and one more thing, when will SGTFLIPFLOP's new bouquets containig FTA folder be released. Can't wait!!!!!
Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required!
Also added Picons for Sky UK , All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
