SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • SGTFlipFlop
    • Sep 2009
    • 1002
    #541
    Originally posted by smirnoff_rules
    Working ok in birmingham living+1 ?
    Its Sky Livingit +1
    will update them in the morning
    • lincsat
      • 1228
      #542
      I believe that MGM HD has moved recently as well
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #543
        Never had time this morning, Will do it later today
        • RuberDuck
          • 1724
          #544
          indeed it has.
          2011-05-05
          • SGTFlipFlop
            • Sep 2009
            • 1002
            #545
            Here is the latest update
            DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
            Enigma 1 = Dreambox 500, 600, 7025
            Enigma 2 = Dreambox 800, 8000, 500 HD
            Updates: 7th May 2011
            Bouquet Updates
            Challenge (Frequency Change)
            Desh TV (New Channel)
            MGM HD (Frequency Change)
            Playhouse Disney Renamed to Disney Junior
            Playhouse Disney +1 Renamed to Disney Junior +
            Sky Livingit +1 (Frequency Change)
            Removed Channels
            Challenge
            MGM HD
            Sky Livingit +1
            Picons
            Updated new channels
            I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
            ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
            Also added Picons for Sky UK,
            All correctly mapped and a few obscure ones missing only
            Use any FTP client, DCC for example, to transfer the picon directory to
            one of the following paths on Flash, HDD, CF or USB respectively:
            /usr/share/enigma2
            NOT recommended, because of limited capacity of the flash memory
            /media/hdd
            HDD will keep running indefinitely and may affect image performance
            /media/cf
            Recommended if CF available and successfully mounted (8000/800)
            /media/usb
            Recommended if USB available and successfully mounted (8000/800)
            Picon will display immediately on zapping, no further setup required!
            Always remove old picons from Dreambox before uploading new ones,
            Sometimes they don't overwrite correctly
            Please keep this thread clean, Use the Thanks button rather than posting on the thread
            • markshore
              • Oct 2010
              • 120
              #546
              Hi great bouquets but having some trouble with mine i have modified them for use with air video for iphone by adding another bouquet to yours have ticked allow duplicate entries in user bouquets in settings.
              Opened dreambox edit and opened your latest bouquet, opened tools and went to compare loaded services with services from dreambox selected all and updated active file set (showed the changed new frequency for MGM HD as delete?)thought it worked but no it has not any ideas as to where i am going wrong.
              Regards
              Mark
              • SGTFlipFlop
                • Sep 2009
                • 1002
                #547
                Regards
                Mark
                If I read this correctly, You are comparing a new updated set of files against an old set, Hence it coming up as delete.
                You need to compare by loading the newest updated file rather than an old one
                • markshore
                  • Oct 2010
                  • 120
                  #548
                  Hi so what would be the correct way to do this this, info that i got was from this site, basically open dreambox edit select your new file open tools and select compare loaded services (your new one) with services from dreambox select update active file set job done?
                  Regards
                  Mark
                  • NO10RANGER
                    • 58
                    #549
                    Hi have problems copying them over i'm using flashftp is this the correct software to use if not could someone piont me in the correct direction cheers
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      #550
                      • raz0r19
                        • Nov 2010
                        • 9
                        #551
                        Many Thanks
                        Hi SGTFlipFlop, Just wanted to take this oppurtunity to say many thanks for all your work in providing this excellent bouquet pack & picons. Have used them for last 5 months & they have enabled me to keep up to date with the many channel changes over this time. Best bouquet pack I have used & you deserve all the thanks for helping the community out. Thanks again & keep up the good work. raz0r
                        • tint2000
                          • 21
                          #552
                          is there problems with your new enigma 1 bouqets as i load them up but all i get is removed service but then i load your older one up 19.04.2011 and its perfect
                          • SGTFlipFlop
                            • Sep 2009
                            • 1002
                            #553
                            Works perfect just tried it
                            • tint2000
                              • 21
                              #554
                              im going to try it again now i used dcc method & dream edit method on a 500s. ill let you know
                              • tint2000
                                • 21
                                #555
                                exactly the same again removed service, never had a problem before now! tried these new bouquets on 3 diff 500s always says removed service but yout 19/04.2011 work perfect except removed service for sky livingit+1 and challenge
