SGTFlipFlop SKYUK Bouquets - Updated Regularly
Here is the latest update
DreamboxEdit 5.0.1.0 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 1st March 2012
Bouquet Updates
Community Channel (New Channel)
Pick TV (New Channel)
Pick TV +1 (New Channel)
Sky1 Ireland (New Channel)
Sky Sports F1 (New Channel)
Sky Sports F1 HD (New Channel)
F1 channels have gone live and are now in Sports Bouquets
Moved Sky HD Channels to the first folder, There are plenty of HD channels now to have it as a main bouquet
Removed Channels
Picons
Updated newest channels
These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
a quick question, is their any way to just update the existing bouquet on the dreambox.
I have set up my bouquet by moving channels into a way i really like, but i want to update the bouquet with the latest informtion.
Is their anyway to update the channel list, keeping everything in the positions they are in, or do i have to start from scratch?Comment
have you tried turing off the box and leaving off for two mins then try and turn back on
altering the bouquets wont affect the start up of the box, have you downloaded any other plugins since you last restarted your box? and this is the first time you have restarted the box since then?Comment
On a forum?
I also seen someone selling them on eBay aswell, 99p a shot, All these updates will be keeping him loaded
Yeah downloaded it all he does is changes a few channels and adds his name
Saying that, Having a better look at it he changes quite a lot, But still no need to add his name to the file
