Commando 14.7 DM500 Release
  • saayinla
    • 162
    #436
    Originally posted by gooleys12
    Does anyone know how to set up mgcamd with this Img ?
    Thanks for the info if anyone can help .
    What folders do the files go in ?
    Supported softcams (correctly named) are:
    CCcam
    evocamd
    gbox
    mgcamd
    newcamd
    oscam
    and it/they belong in the /var/bin/emu folder
    For mgcamd - you need to add the provided libcrypto.0.9.7 file to /var/lib -this is included in the file. FTP to copy.
    U then need to download the mgcamd 1.38 file Google it.
    Copy the following files to the box all files cAsE sensitive!
    mgcamd in /var/bin/emu/
    mg_cfg, newcamd.list in /var/keys/
    sealions in cccamd.list in /var/keys/
    Note it will be named mgcamd.ppc copy it to the right place then edit and change the name only to mgcamd save and close.
    Close and restart should be to go.
    Sent from my One V using Tapatalk 2
    Anyone care to expand on this.
    I hope the sealions was a typo, can someone comment on that , also when I downloaded mgcamd 1.38 there was no cccamd.list inside.
    • scaffolder
      • Nov 2010
      #437
      Hi will this image work on a 500c thanks
      • pjmorie
        • Mar 2012
        • 45
        #438
        Try the sealions in newcamd.list.
        • pjmorie
          • Mar 2012
          • 45
          #439
          Originally posted by delly007
          hi just wondering if anyone else is having trouble with rte 2 not clearing
          Same here with RTE TWO, no picture or sound but the teletext service is working!! It's not showing as scrambeled and rescan has made no difference.
            Just updated commando image on line and autoupdated channel list, how can I get BT sports loaded in channel list???
            • Kalipo
              • 1687
              #441
              Errr you need to run auto bouquets thingy
                Tried all that stuff mate, lost the bottle now!!!!!
                • PaphosAL
                  Old Git
                  • 1064
                  #443
                  Hi All,
                  Anyone knows if mgcamd is installed in this image, if yes how do I access it.
                  Thanks in advance.
                  Commando has, and always WILL be a FTA image! There are NO softcams installed. However, for educational purposes and testing by individual users (as allowed under EU Law), menu support for 3rd party softcams is included.
                  Please just read the 'Softcam' section of the 'General Hints and Tips' helpfile that is packaged with C14.7 and you'll soon get the drift. Note that your proposed tests will also require the supporting lib file for your intended software. This is packaged too.
                  Enjoy! AL
                  • PaphosAL
                    Old Git
                    • 1064
                    #444
                    The latest C14.7 update is a quicky, not incurring a root reflash, therefore no reboot. But it does include a new satellites.xml and myservices.xml for Scan and AutoBouquets to use.
                    So if things don't seem to be quite right after the update, just reboot your box and THEN run AutoBouquets, simples!
                    • MW35
                      • Feb 2012
                      • 70
                      #445
                      done the update but now the EPG is terrible half of the channels doesn't say what's on now never mind that next!
                      • paul93
                        • 50
                        #446
                        commando 14.7 working a treat but i dont get one channel that should be in international or in new its called news 18 india should be on this freq 11344/27500v can some one help me how i can do it scan manually or any other method your help will be appericiated.
                        • psats
                          • 823
                          #447
                          go into bouqet editor and add it to international.
                          menu / srvices / b editor / international / green / find the channel press / ok
                            Commando_14-7 corupted file brocken, please some 1 download a fresh file?
                            Thanks for your time.
                            • pjmorie
                              • Mar 2012
                              • 45
                              #449
                              News 18 India shows up in the A-Z Bouquet but you may not have this enabled. Provided you are on the latest release with all the updates then to enable this bouquet press BLUE -> BLUE -> GREEN -> RED -> YELLOW.
                              After running AutoBouquets you should now have a bouquet called Astra 28.2E which is an A-Z listing of all the channels.
                              • paul93
                                • 50
                                #450
                                Thanks psats it worked a treat.
