If you're still having problems I will be able to talk you through it on messenger tonight if that helps
Catseyes ??? where??
just get a pic of dish flashing in top right corner of screen and thats all i get, not to worry going over to the chap i bought it off and he is going to change the bos for me so will see how we get on with a new box,
tonynwComment
Did you say you got another box working on the dish?
Is it possible to try the box on some mates Sky dish?
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
When you set up your tuner configuration you did change the voltage option because it sounds like you have no power going to dish .Comment
where should i change the power and to what ??? will give it one last go then if it dosnt work there will be 1 x DM800 hd and 2 x DM 500s up for grabs.
cheers
tonynwComment
Cant see there being problems with 3 different boxes mate.
On some images yiou can change the Tone Ampitude in tuner configuration.
The motor gets its power from the box through the coax.
In my image ive 4 options and if its on the wrong one it wont move the dish.
Look at the picture in post 4 from your other thread.
When you configured your tuner and changed your long and lat one of the options is voltage I'm sure you need to make it + voltage it will say exactly what voltage in the sticky you read before about setting up you box for usuals.Comment
try setting it up for a static dish , you should pull a signal if the dish is alligned correctly and pointing at 28.2 e
configure like this picAttached Files
on my motorised dish my config is like this
this is on an 800SE , so may be differant layout in standard 800 (values should be pretty much the same tho)Attached Files
