cheers m8 will have a look @ this, it's just what i think ive been looking.
SKY UK BOUQUETS
This topic is closed.
Updates : Few frequency changes,
Zone Horror & Zone Horror +1 changed to Horror & Horror +1
ESPN HD new frequency
Hope you find them useful
Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find)
DreamboxEdit :- Download DreamboxEdit from SourceForge.net
Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
Use any FTP client, DCC for example, to transfer the picon directory
to one of the following paths on Flash, HDD, CF or USB respectively:
/usr/share/enigma2
NOT recommended, because of limited capacity of the flash memory
/media/hdd
HDD will keep running indefinitely and may affect image performance
/media/cf
Recommended if CF available and successfully mounted (8000/800)
/media/usb
Recommended if USB available and successfully mounted (8000/800)
Picon will display immediately on zapping, no further setup required!
nice boughet have u got any european ones m8.Updates : Few frequency changes,
/usr/share/enigma2
/media/hdd
/media/cf
/media/usb
thanksComment
Updates : DM800 Bouquet Sci-Fi, Sci-Fi +1 & Sci-Fi HD have been rebranded to Syfy, Syfy +1 & Syfy HD.
Sky News HD Added to news bouquet (Not Active until next Thursday)
Luxe TV HD & Rush HD have new channels showing up, But old ones are still working at present keep an eye out for them stopping.
DM500 same as above but without the HD channels
Code:Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required!
got this working on my dm500s with pli jade 3 image, saves so much time and and great order, thanks for sharing, will be getting a dm800 soon will flash Nabilo BH 0.12 image, just wondering if the pic icons will work on it, and which directory to put them in ?
Thanks again
