SKY UK BOUQUETS
This topic is closed.
  • madmac1
    • 6
    #121
    thanks have been looking for this for a while now
    • chris2021
      • Jul 2010
      thanks, just getting started with dm500 helps alot
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #123
        Updates: 13th JUly 2010
        DM800 Bouquet
        Ideal Extra (New Frequency)
        Cinemoi movies (New Frequency)
        Ramadan TV (New Channel)
        Five HD (New Channel)
        Removed Channels
        Sky Travel
        Up & Coming TV
        Added Full Regional Listings
        DM500 Bouquet
        Same as above except HD content
        Hope you find them useful, Please say Thanks
        Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find)
        DreamboxEdit :- Download DreamboxEdit from SourceForge.net
        Also added Picons for Sky UK (Base set from Picon4U) and the rest   updated by myself
        Use any FTP client, DCC for example, to transfer the picon directory
        to one of the following paths on Flash, HDD, CF or USB respectively:
        /usr/share/enigma2
        NOT recommended, because of limited capacity of the flash memory
        /media/hdd
        HDD will keep running indefinitely and may affect image performance
        /media/cf
        Recommended if CF available and successfully mounted (8000/800)
        /media/usb
        Recommended if USB available and successfully mounted (8000/800)
        Picon will display immediately on zapping, no further setup   required!
        • mapex
          • Jul 2010
          • 209
          #124
          Right hears the muppet questiong
          wtf is a sky BOUQUETS ???? tried
          google but cant seem to find a
          good answer.....call me assholio...
          i dont mind
          • SGTFlipFlop
            • Sep 2009
            • 1002
            #125
            i dont mind
            Channel lists same as Sky TV
            • mapex
              • Jul 2010
              • 209
              #126
              Right.........gotcha
              • wendobas
                • Jul 2010
                thank you
                thank you for saving so much time. would be stuck here all day
                • burgemaster
                  • Jul 2010
                  • 33
                  #128
                  Can anyone please help.
                  I can transfer the files with dreamboxedit but when i then Hit "Update Settings to Dreambox" button i get an error about "cannot connect to dreambox on IP X.X.X.X"
                  I have managed it just ONCE in about 50 attempts, this happened when rebooting everything and having various dreamboxedits open.
                  Its a DM500C with Jade PlI image. I know all the paths are correct as it worked once!
                  Thanks in advance!
                    Sometimes when you ftp the files and the box doesn't update, a reboot usually sorts it out
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      #130
                      Thanks in advance!
                      Unless you have set a Static IP for your Dreambox the IP might change.
                      Off the top of my head wth Pli do this, Menu > 6 > System settings > Network and check to see what IP is assigned, Use that IP in your Dreamboxedit profile then you can FTP the files over
                      • burgemaster
                        • Jul 2010
                        • 33
                        #131
                        WOW !
                        thanks for the mega fast replies!!
                        I have a static IP, I can always FTP the files, but Here are the errors I get:
                        This might take up to a few minutes to let the Dreambox complete the reloading.
                        Telnet status: Connecting to 192.168.1.10.
                        Telnet status: Connected.
                        PLi dm500 Jade 20090627 (based on 1.09)
                        welcome on your dreambox! - Kernel 2.6.9 (12:03:49).
                        dm500 login:
                        Sending username root
                        root
                        Password:
                        Sending password dreambox
                        BusyBox v1.01 (2009.06.06-23:06+0000) Built-in shell (ash)
                        Enter 'help' for a list of built-in commands.
                        root@dm500 ~ #
                        Sending user command: killall -9 enigma2
                        k
                        illall -9 enigma2
                        killall: enigma2: no process killed
                        root@dm500 ~ #
                        When it DID work i only got about 4 lines ?
                        somthing like
                        stage 1 complete, stage 2 complete?
                        • SGTFlipFlop
                          • Sep 2009
                          • 1002
                          #132
                          I see you have enigma2 listed there.
                          Try this Options > Profiles, Find your Profile and click Cable receiver at the bottom, Save and try again.
                          • burgemaster
                            • Jul 2010
                            • 33
                            #133
                            Sorry I meant to say 500S not a C
                            When it does work (1 in 50 attempts) i get:
                            Network response: +ok
                            First of two steps completed.
                            Second of two steps completed.
                            Reload command ready.
                            As ive managed to get your great bouquet on I guess I can worry about this another time and edit it slightly on the box
                            Thanks for the help
                            • needy
                              • 105
                              #134
                              hi mate, im trying to put your bouquet on dm500s, when i try through dreamboxedit i get the error code "contains no services or lamedb file" any ideas whats wrong thanks.
                                Make sure your set to enigma 1 in dreamboxedit. If that doesn't work try a different version of dreamboxedit
