SKY UK BOUQUETS
This topic is closed.
  • 00360362878
    • Mar 2010
    • 488
    #136
    For some reason I have nothing but trouble with drembox edit. I always use dreamset 2.27 always works for me.
    Worth a try mate.
    • needy
      • 105
      #137
      tried a different dreamboxedit, it allowed me to load the file and after reboot still nothin showin in bouquet, so tried to load file again and got same error as before
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #138
        Originally posted by needy
        hi mate, im trying to put your bouquet on dm500s, when i try through dreamboxedit i get the error code "contains no services or lamedb file" any ideas whats wrong thanks.
        Make sure your Profile in options is set to Satelitte and not Enigma2
        • dave-h
          • Apr 2010
          • 659
          #139
          Worth a try mate.
          Me too...Nearly always have issues with DBE and a 500s,so use Dreamset now. Much more reliable,works first time everytime!!!
          • needy
            • 105
            #140
            cheers guys ill give that a go
            • needy
              • 105
              #141
              hi guys got it to load with dreamset 2.27 thanks, next question is about the epg, i know i cant have a 7 day due to memory just wonderin whats the best i can have, an do i have to change my image to improve it, the image is nabilosat dm500 v.0.8
              • billy2
                • 1381
                #142
                did you set your ip in dreamboxedit the same as your box and press save
                please press the little red THANKS tab
                if I helped if not press the green tab to tell me to f**Koff
                • SGTFlipFlop
                  • Sep 2009
                  • 1002
                  #143
                  Updates: 29th July 2010
                  DM800 Bouquet
                  Comedy Central HD (New Channel)
                  Blueberry TV renamed to Bilberry TV
                  Removed Channels
                  Baby First TV
                  Channel TBC
                  Fobo Movies
                  Few other minor changes
                  Added Full Regional Listings
                  DM500 Bouquet
                  Same as above except HD content
                  Hope you find them useful, Please say Thanks
                  Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find)
                  DreamboxEdit :- Download DreamboxEdit from SourceForge.net
                  Also added Picons for Sky UK (Base set from Picon4U) and the rest   updated by myself
                  Use any FTP client, DCC for example, to transfer the picon directory
                  to one of the following paths on Flash, HDD, CF or USB respectively:
                  /usr/share/enigma2
                  NOT recommended, because of limited capacity of the flash memory
                  /media/hdd
                  HDD will keep running indefinitely and may affect image performance
                  /media/cf
                  Recommended if CF available and successfully mounted (8000/800)
                  /media/usb
                  Recommended if USB available and successfully mounted (8000/800)
                  Picon will display immediately on zapping, no further setup   required!
                  • K4M1K4ZI
                    • Jul 2010
                    • 4
                    #144
                    HD Channels
                    I cant find HD channels in your bouquet. I can see other categories but not the HD ones. I have a dreambox 800HD. Any ideas? Also, how to a assign a particular picon to a particular channel?
                    Thanks in advance
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      #145
                      Check inside the categories, They are there, Been told Sky HD box has a Bouquet just for HD channels, I don't see the point in this so didn't add it
                      • lombard
                        • Aug 2008
                        • 793
                        #146
                        thanks again, you added picons to five hd and some others missing, thanks
                        • K4M1K4ZI
                          • Jul 2010
                          • 4
                          #147
                          Picons
                          How do you add Picons to a channel:
                          Eg: How to I add a Picon for Sky Sports4 HD
                          • theobserver
                            • Sep 2009
                            • 41
                            #148
                            Worked perfect for DM500.
                            use DreamboxEdit v30
                            FTP to box
                            Click "Reload settings on dreambox"
                            30 seconds later it's ready to use
                            • scudno1
                              • Sep 2009
                              • 52
                              #149
                              sky sports news HD
                              does anyone know when sky sports news HD will be added.
                              • SGTFlipFlop
                                • Sep 2009
                                • 1002
                                #150
                                23rd August
