SKY UK BOUQUETS
This topic is closed.
  • SGTFlipFlop
    • Sep 2009
    • 1002
    #226
    Updates: 4th September 2010
    DreamboxEdit 3.0.2.0 Used (Recommended)
    DM800 Bouquet
    Bangla TV (New Frequency)
    Blue Hustler TV (New Frequency)
    Living HD (New Channel)
    Sangat TV (New Channel)
    Vintage TV (New Channel)
    Virgin 1 Renamed to Channel One
    Virgin +1 Renamed to Channel One +1
    Removed Channels
    Channel M
    JML Lifestyle
    oMusic TV
    DM500 Bouquet
    Same as above except HD content
    Right here we go, Decided to set myself up a multisat bouquet, As I only watch Sport on these Satellites that's all I have set-up, But a full scan has been done and access to the rest of a Satellites channels will be available via All Channels (DM500) or Services (DM800).
    This is still very raw to me as I've just set-up a Motorised dish, So no doubt in the coming weeks I'll make changes, I don't have many Satellites open to see if they all work, So I need updates from you guys, Please leave feedback on these new Bouquets for good or bad I need to know if they work or don't.
    On these bouquets Sly UK will always be the main Satellite listed and the rest as feeders.
    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
    Also added Picons for Sky UK (Base set from Picon4U) and the rest   updated by myself
    Use any FTP client, DCC for example, to transfer the picon directory
    to one of the following paths on Flash, HDD, CF or USB respectively:
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
    Picon will display immediately on zapping, no further setup required!
    • fungusfeet
      • Apr 2010
      • 6
      #227
      Your DM800 non-multi is just an empty folder...
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #228
        Arghh what the ~~~~ is going on LOL
        • SGTFlipFlop
          • Sep 2009
          • 1002
          #229
          Fixed it
          • Mickouse
            • Aug 2010
            • 4
            #230
            Thanks a lot. Sky UK settings are hard to find
            • clapton64
              • 14
              #231
              Thanks for all your great work. Much appreciated
              • chavscum
                • 6
                #232
                ta for these, wondered where Channel One had come from on my Sky box...now I know ;-)
                • givecredit
                  • Aug 2008
                  • 6
                  #233
                  When i install SGT picons or picons from dream elite i get no picon for ITVHD. Any idea why, is it just that there isnt one?
                  Also everytime i reload channel bouquet i have to fix audio settings on MTV channels. Is there a better fix for this?
                  • SGTFlipFlop
                    • Sep 2009
                    • 1002
                    #234
                    Do you delete the Picons you had before, You need to completely overwrite every file.
                    ITV HD works np
                    For the Audio, Go into options and find the setting for AC3 default turn that on, Then download the plugin called 2lang, Thats all you need to stop changing the audio about
                    • thewizardofodds
                      • 924
                      #235
                      DM800 Bouquet
                      Removed Channels
                      Channel M
                      JML Lifestyle
                      oMusic TV
                      DM500 Bouquet
                      /usr/share/enigma2
                      /media/hdd
                      /media/cf
                      /media/usb
                      Dont want to sound dumb but where do these go in my box. only just set up my box today so still bit clueless
                        Easiest way if your new is to download Dreamboxedit and it will ftp them to the correct folders for you
                        • thewizardofodds
                          • 924
                          #237
                          Job done. cheers lads.
                          • SGTFlipFlop
                            • Sep 2009
                            • 1002
                            #238
                            Updates: 9th September 2010
                            DreamboxEdit 3.0.3.0 Used (Recommended)
                            DM800 Bouquet
                            Added HD Only Bouquet
                            Added Sky Box Office Bouquet again (Removed last time)
                            ** Dreambox 800 Update Only This Time **
                            /usr/share/enigma2
                            /media/hdd
                            /media/cf
                            /media/usb
                            • rossi2000
                              • 37
                              #239
                              hi mate
                              great work as always with the bouquets + picons
                              i have a question regarding the picons, i have deleted my old picon folder from usb pendrive and uploaded yours, ive noticed a few that arent displaying.
                              Good Food HD
                              Comedy Central HD
                              Sky Movies Showcase HD
                              Sky Movies Thriller HD
                              i dont know if its a case of them not being present in the pack or there is something wrong with what ive done.
                              • SGTFlipFlop
                                • Sep 2009
                                • 1002
                                #240
                                Originally posted by rossi2000
                                hi mate
                                Good Food HD
                                Comedy Central HD
                                Thanks for that they seemed to have changed the unique code, Will update them later
