Guide: Flashing a Dreambox with Dreamup
  • biggp
    #31
    also cant seem to get cccam to work is that because of old software sorry did not say what box its a dbox 500
    • Nibor
      • 27
      #32
      I would have flashed it with a new FW, and installed a cam that have what you need.
      You will find guides in this forum how you can do this...
      I would recommend a MaxVar image.
      • najwalia
        • 17
        #33
        HI ,TO ALL
        I HAVE DM800 HD ORIGINAL , I FLASH GEMINI IMAGE VIA WEB BROWSER LAST TIME TO MY BOX. IT WAS VERY EASY FOR ME .JUST I PRESS POWER BUTTON HOLD FOR SOME TIME ***STOP*** THEN I GOT IP . ... NOW I WANT TO CHANGE IMAGE ,BUT I AM NOT GETTING ***STOP*** OR IP . IT IS SAME RECEIVER SAME CABLE SAME ROUTER .CAN ANY BODY HELP PLEASE .
        THANK YOU
        • Nibor
          • 27
          #34
          Originally posted by najwalia
          HI ,TO ALL
          THANK YOU
          start your box the normal way, uncheck DHCP in network, and try again...
          do you reach it via a browser?
          • najwalia
            • 17
            #35
            THANK YOU FOR REPLAY MR NIBOR
            I TRY ED THAT WAY ALSO .DHCP OFF .I PUT IP 192.168.1.7
            BUT STILL SAME .IF I MAKE DHCP ON .192.168.1.2 IP IS SHOWING IN THE RECEIVER , BUT WHEN I PRESS POWER BUTTON BLACK DISPLAY ON THE RECEIVER LED , I COULD NOT REACH TO THE BROWSER THIS TIME , LAST MONTH 2 TIME I DID WITH BROWSER EASY ,BUT NOT THIS TIME . THANK YOU
            • Nibor
              • 27
              #36
              BUT STILL SAME .IF I MAKE DHCP ON .192.168.1.2 IP IS SHOWING . THANK YOU
              if there is no green V next to DHCP and it is 192.168.1.2 you should try to restart your DB, hold the power button in when you boot it, if it not starts as normal, try to use fex Firefox and go to 192.168.1.2
              Most likely your problem is solved
              • najwalia
                • 17
                #37
                NO SIR , SAME THING . EVEN I RESTART DM , RESTART ROUTER , BUT ITS GOING EVERY TIME IN TO OLD IMAGE . HOW TO USE FIX FIREFOX .I AM SORRY . FOR MY ENGLISH
                THANK YOU
                • Nibor
                  • 27
                  #38
                  THANK YOU
                  fex=for example
                  pull out the power cord, push and hold the power button(on the dreambox, NOT the remote), insert the power cord AS YOU HOLD THE POWER button in...
                  It should now stop and give you a DHCP adress, or 192.168.1.2 if you have set this IP.
                  Then try with Firefox, Internet Explorer, Opera etc on 192.168.1.2, OR the adress in the DB display
                  • Nibor
                    • 27
                    #39
                    any luck...?
                    • najwalia
                      • 17
                      #40
                      THANK YOU MR NIBOR
                      I DID THAT BUT ON DREAMBOX LED BLACK NOTHING IS THERE ,BUT I CAN SEE BACK OF DM NETWORK CONNECTOR RG 45 , IN THE CONNECTOR THERE IS RED+GREEN LIGHT .THEN I TRYED IN WEB BROWSER WITH IP .IT IS GIVEN SOMTHING DIFRENT FOR CHANNELS AND OTHERES BUT NOT FOR IMAGE .
                      THANK YOU
                      • Nibor
                        • 27
                        #41
                        seen this?
                        • najwalia
                          • 17
                          #42
                          i knew this
                          ### How to flash a dm800 via web browser ###
                          last time i did with same detraction . but this time bad luck
                          thank you very much mr nibor
                          • najwalia
                            • 17
                            #43
                            mr nibor . can i telnet the image with DCC . if yes . then how
                            thank you
                            • Nibor
                              • 27
                              #44
                              dont remember 100%, but if you use dreamup you should be able to fix it:
                              • kerman
                                • 11
                                #45
                                hello i cant see the files to download and when i want to post new thread i cant find in forum new thread
