DM500s Hell Aborted by User upload
  • garry1312
    • Oct 2010
    • 2178
    #16
    could also give iport a try and if you can connect to the box telnet or use flash wizard.
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
    • pepe17
      • Mar 2010
      • 5
      #17
      XeroxUk, I have got the same issue like yours.
      I have tried all the ways with different dreamup version and different images, but same msg even with the patched dreram box.
      When I attach the box I get this this:
      19:15:24 box type: DM500
      19:15:34 Ping result: OK, box is alive and speaking to us ;-)
      And then I flashed with erase.img, I get this:
      Box was flashed sccessfully!
      19:16:38 Uploading file to box...
      19:16:41 calculating CRC32 on STB...
      19:17:08 erasing flash...
      19:17:10 box is flashing from its memory...
      19:17:15 calculating CRC32 on STB's flash...
      19:17:15 "flash erase"...
      19:20:36 OK, flash-copy succeeded
      Now I flashed the original image, after a while comes this:
      ERROR,upload aborted!
      Is the box still working or dead???
      Help pls!
      thx.
      • pepe17
        • Mar 2010
        • 5
        #18
        Finally, I got it working!!
        Firstly, I i used patched DreamUp to flash the box with erase.img (I did twice) then without disconnecting I patched pliJade image and it went through.Connecting to tele and works fantastic.
        Thx to all!!!!
        • ehf
          • Feb 2011
          I guess the DreamUp updated version, detects pirate dreamboxes and that is why it refuses to work correctly.
          I have the same problem, with USB-COM cable and Windows 7.
          • guli
            • 4
            #20
            [quote=zaf786;891550]
            Originally posted by xeroxuk
            Hi Guys,
            I have read through the forum with regards to this issue that I am having with my DM500s box and tried everthing suggested still to no avail.
            I am trying to reflash my DM500s which was using a PLIjade image working fine until last week the box froze, so I decided to reflash it.
            When trying to reflash I get the same error over and over again with the following:
            PLIjade image
            NabiloSat Max Var image
            and I keep getting aborted by user about 10% of the way through.
            I tried to Flash erase and get the same error. Although when I leave the box for about 30Mins and then try to flash erase the erase does work.
            But the flasing of the image does not work at all keeps aborting no matter which version of dreamup I use.
            PC Setup:
            I am on win xp which was used to flash the same box many times before without any issues.
            Tried changing to a different PC same problem. Tried changing the Null Cable still the same problem.
            Versions of Dreamup used:
            2.1.8A
            1.3.2.1
            1.2.2.0
            1.3.2.1
            1.3.3.0
            1.3.3.1
            1.3.3.4
            1.3.3.5
            1.3.3.6
            All of them so far no Joy. The box always responds when serial and power are plugged in. But just unable to complete flash.
            Any help on this would be really appreciated.
            Thanks[/QUOTE
            try this version os dreamup
            i have had the same problem but found dreamup v1.2.2.0 works all the time
            cheers
            • jfish
              • 799
              #21
              I had exact problem with the error aborted by user
              its due to the version I was running. The attached verison 2.1.5 works perfectly for me
              • aissa09
                • 1622
                #22
                the archives is either in unknown format or damaged
                please send me another thaank
                Best regards aissa
                AISSA SERVICE ELECTRONIQUE
                BLIDA car radio decodesigpic
                • jfish
                  • 799
                  #23
                  nothing wrong with it, just downloaded the file I attached, unzipped it and executed Dreamup.
                  • kevglady
                    • Feb 2011
                    • 34
                    #24
                    Hi Guys,
                    PLIjade image
                    PC Setup:
                    2.1.8A
                    1.3.2.1
                    1.2.2.0
                    1.3.2.1
                    1.3.3.0
                    1.3.3.1
                    1.3.3.4
                    1.3.3.5
                    1.3.3.6
                    hello mate i had same problem try a different version of dreamup worked for me....
                    • svart
                      • Jul 2011
                      I bought my dm 800hd pvr and 500 at dreamboxcom.com. Is it clones?
                      • miltos34
                        • Oct 2011
                        i need an erase.ing to try it pls help me
                        • mtv1
                          The Stig PT
                          • 4413
                          #27
                          here mate good luck
                          • z1g3
                            • Mar 2012
                            Dream Up
                            Where to find patched version dreamup ?
                            • jgeorge_cabuhat
                              • Apr 2010
                              DM500S not working
                              Originally posted by Curious123
                              Try flashing this erase image first and then retrying the pli image.
                              Thanks for the information. i hope its help. my dreambox is not working...
                              • aEGo2
                                different version of dreamup worked for me too
