could also give iport a try and if you can connect to the box telnet or use flash wizard.
DM500s Hell Aborted by User upload
XeroxUk, I have got the same issue like yours.
I have tried all the ways with different dreamup version and different images, but same msg even with the patched dreram box.
When I attach the box I get this this:
19:15:24 box type: DM500
19:15:34 Ping result: OK, box is alive and speaking to us ;-)
And then I flashed with erase.img, I get this:
Box was flashed sccessfully!
19:16:38 Uploading file to box...
19:16:41 calculating CRC32 on STB...
19:17:08 erasing flash...
19:17:10 box is flashing from its memory...
19:17:15 calculating CRC32 on STB's flash...
19:17:15 "flash erase"...
19:20:36 OK, flash-copy succeeded
Now I flashed the original image, after a while comes this:
ERROR,upload aborted!
Is the box still working or dead???
Help pls!
thx.Comment
[quote=zaf786;891550]Hi Guys,
I have read through the forum with regards to this issue that I am having with my DM500s box and tried everthing suggested still to no avail.
I am trying to reflash my DM500s which was using a PLIjade image working fine until last week the box froze, so I decided to reflash it.
When trying to reflash I get the same error over and over again with the following:
PLIjade image
NabiloSat Max Var image
and I keep getting aborted by user about 10% of the way through.
I tried to Flash erase and get the same error. Although when I leave the box for about 30Mins and then try to flash erase the erase does work.
But the flasing of the image does not work at all keeps aborting no matter which version of dreamup I use.
PC Setup:
I am on win xp which was used to flash the same box many times before without any issues.
Tried changing to a different PC same problem. Tried changing the Null Cable still the same problem.
Versions of Dreamup used:
2.1.8A
1.3.2.1
1.2.2.0
1.3.2.1
1.3.3.0
1.3.3.1
1.3.3.4
1.3.3.5
1.3.3.6
All of them so far no Joy. The box always responds when serial and power are plugged in. But just unable to complete flash.
Any help on this would be really appreciated.
Thanks[/QUOTE
try this version os dreamup
i have had the same problem but found dreamup v1.2.2.0 works all the time
cheersComment
I had exact problem with the error aborted by user
its due to the version I was running. The attached verison 2.1.5 works perfectly for meAttached FilesComment
hello mate i had same problem try a different version of dreamup worked for me....Hi Guys,
PLIjade image
PC Setup:
2.1.8A
1.3.2.1
1.2.2.0
1.3.2.1
1.3.3.0
1.3.3.1
1.3.3.4
1.3.3.5
1.3.3.6
ThanksComment
here mate good luckAttached FilesComment
