Oscam + CCcam 2.1.3
  • davvo
    • Apr 2009
    • 666
    #61
    Originally posted by thered
    cheers m8 just to confirm it is the server not myself who needs to change it then?
    yeah the server needs to change to oscam
    • davvo
      • Apr 2009
      • 666
      #62
      Originally posted by u.s
      upgrade to the latest oscam.ppc
      Multiupload.com - upload your files to multiple file hosting sites!
      i can confirm that you do not need boxkey for your sly card
      yeah your right
      upgraded to the latest oscam
      no boxkey needed
      im still learning about oscam
      All the latest versions of OScam do NOT need the 0963 BoxID in the oscam.server file.
      OScam now reads the boxid directly from the card during start-up.
      • davvo
        • Apr 2009
        • 666
        #63
        @thered
        the old blue yellow house sly card
        the caid is 0961
        the new white cards are caid 0963
        thats why they dont work
        • thered
          • Aug 2008
          • 4915
          #64
          Originally posted by davvo
          @thered
          the caid is 0961
          well the cards dead basically anyway but from what you are saying if i wanted to use my dead card i could just change the oscam configuration to 0961 and it would work
          • davvo
            • Apr 2009
            • 666
            #65
            sly just 0963
            you can try 0961
            all 3 files need editing restart oscam
            whether it works on picktv ??
            • thered
              • Aug 2008
              • 4915
              #66
              no is the answer
              im not sure but didnt pick tv used to be sky 3 because it used to clear that
              • davvo
                • Apr 2009
                • 666
                #67
                how long ago
                • father ted
                  • Feb 2008
                  • 1389
                  #68
                  silly question but does oscam auto-update your card?????
                  • davvo
                    • Apr 2009
                    • 666
                    #69
                    AU over CCcam
                    Many people still use CCcam as client, but unfortunately AU will not work with the CCcam protocol. For AU to work, you should set up OScam and CCcam to use CAMD3 protocol, with an L line in CCcam.cfg. The following is an example of two S02 cards which are updated by a CCcam client through the NewCamd protocol (N Line).
                    HD+
                    Unfortunately, OSCam cannot update an HD+ card with a CCcam client, neither by NewCamd, nor by Camd3 protocols. If the server also runs a CCcam server, you can use it as a workaround.
                    "Direct connection" NOT OK:
                    CCcam client connected to OScam server through N-line or L-line.
                    "Indirect" OK:
                    CCcam client through C-line to CCcam server and CCcam server through N-Line to OSCam
                    e
                    • RuberDuck
                      • 1724
                      #70
                      no is the answer
                      to answer your question no a old yellow house card ( caid 0961 ) will not work. sky terminated all of these cards once the rollout of the new white ( caid 0963 ) cards had been completed.
                      • jfish
                        • 799
                        #71
                        whats the current state of play with pick tv
                        is cccam not clearing but oscam is
                        any other channels sly have implemented this anti cs measures.
                        • davvo
                          • Apr 2009
                          • 666
                          #72
                          oscam reads card and clears pick tv then can pass to other cams
                          cccam newcs or any other cam not clearing pick tv as card readers
                          other channels with anti cs measures
                          dont think so YET
                          sly sports 1234 and sly 1 and 2 on same transponders
                          as pick tv and picktv +1
                          • slick_dick
                            • 2283
                            #73
                            Whats the deal with oscam+cccam2.1.3 once installed??
                            Thanking you
                            “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
                            • davvo
                              • Apr 2009
                              • 666
                              #74
                              keep your original cccam 2.1.3 config
                              and add the N line to your cccam cfg
                              the N line is on page 2 on this thread
                              • slick_dick
                                • 2283
                                #75
                                Awesome just what I wanted to hear,
                                davvo
