Oscam + CCcam 2.1.3
  • slick_dick
    • 2283
    #76
    awesome shiznizz
    SL!CK
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
    • davvo
      • Apr 2009
      • 666
      #77
      leave 127.0.0.1 as it is
      the port in the n line in cccam must match the port in oscam cfg
      which is 12000
      you can change that to what port u like
      but they must match
      • slick_dick
        • 2283
        #78
        +rep left, thanks again
        davvo
        • slick_dick
          • 2283
          #79
          who loves ports?
          SL!CK
          • davvo
            • Apr 2009
            • 666
            #80
            you can change test1 test2 to what u like
            but they must match in both cccam cfg and oscam user
            • slick_dick
              • 2283
              #81
              • satsmo
                • 6397
                #82
                Just for thinking why use CCcam in conjuction with Oscam, I am sure there are better ways............as said just a thought
                BTW I am of course talking about a local only share I would never insinuate other.
                • slick_dick
                  • 2283
                  #83
                  intresting
                  • satsmo
                    • 6397
                    #84
                    I did say look at dvbapi a few pages back.
                    • slick_dick
                      • 2283
                      #85
                      and so you did, didnt take much notice of it earlier as I was not sure but checking now
                      thanks satsmo
                      regards
                      SL!CK
                      • lincsat
                        • 1228
                        #86
                        It's been said elsewhere that DVBAPI is more difficult to configure than CCCam. Apparantly, using MGCamd you can AU the Sky card as well.
                        All this experimenting looks fun, I wish I had the hardware to have a play around
                        • slick_dick
                          • 2283
                          #87
                          I do agree with you there lincsat as it looks very intresting, wish I had the time on my hands to experiment.
                          • satsmo
                            • 6397
                            #88
                            It was a lot more difficult on first release but it is easy enough to configure but takes a bit of time. But as you said the fun is in the tinkering
                            You can AU the Sly card with Oscam if you have dvapi active so no need for another cam. But horses for courses and each person will have a preferred method, I like mine but as said it takes a bit of work.
                            • slick_dick
                              • 2283
                              #89
                              o0o thats sounds very intresting, will be looking into it further as soon as I can
                              +rep left satsmo
                              regards
                              SL!CK
                              • sakiblateef
                                • 311
                                #90
                                Originally posted by davvo
                                @thered
                                you need to edit your configs
                                ln var/tuxbox/config
                                unzip the file below
                                put these 3 files ln var/tuxbox/config
                                - oscam.conf
                                - oscam.user
                                - oscam.server
                                put your boxkey in oscam server file
                                looks like this
                                boxid = yourboxid
                                ( boxkey is like this 12345678 and not like this 12 34 56 78 )
                                put this N line in cccam cfg
                                N: 127.0.0.1 12000 test1 test2 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
                                restart oscam
                                thats it
                                you can log in to oscam via browser
                                DM IP http://192.168.X.X:8888
                                [webif]
                                httpport = 8888
                                httpuser = admin { you can change to what u like in config }
                                httppwd = admin { restart oscam for change to take }
                                config files for both e1 and e2
                                Does this method update the entitlements?
