hi guys just bought a dm800 clone come pre flashed. i am trying to connect the box to pc using dcc and cross over cable. when i try to connect it says error failed socket not connected. tried troble shooting throu windows 7 and it says not a valid ip address. i am very new at this so if some one could help would be much appricaited. cheers kevin
connect to network using dcc for dm800hd
Have you set up your network mate??hi guys just bought a dm800 clone come pre flashed. i am trying to connect the box to pc using dcc and cross over cable. when i try to connect it says error failed socket not connected. tried troble shooting throu windows 7 and it says not a valid ip address. i am very new at this so if some one could help would be much appricaited. cheers kevin
What router you using and have you got Dhcp enabled or not?
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
You need to go into the menu of the Dm 800 and set up the network there mate.
Your Dreambox will have its own ip and the gateway will be the routers ip address.
All this needs to be done before you can download ccams,add bouquets and other unmentoinables which we cant talk about on this forum.
I suggest you look at the red stickys at the top of the Sat Dreambox section and do some reading.
Andy.
Flash a decent image on it like Dreamelite Blackhole.
If you aint a clue and your box has Gemini it will be harder at the beginning to get it up and running as the Gemini server isnt working now.Last edited by andy91; 27 April, 2011, 17:57.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
andy it come preloaded with inigma 2 and ccams i need to add one more thing using dcc but it wont connect to network. i have set the box up for internet connection using the wizord and checked for connection everything fine there it just wont connect to the pc using the cross over cable. what should the settings be set to in the dm menu. is there a sticky that covers what i am looking for. kevinComment
If you want a static ip then leave Dhcp disabled and make your own ip address up but if you want it to assign its own ip address leave Dhcp enabled and it will automatically give it an ip address.
The only problem with this is if you have several wireless things in your house like ipods,xbox live that might clash with it so i select static for mine.
Dont forget you will need to add in network on the Dreambox the subnet and gateway.
Netmask is normally 255.255.255.0 and the gateway is the routers ip address.
You can access all from a laptop to see if it is working ok.
Try Flashfxp its in downloads,im guessing your trying to ftp a sea lion over?
Try this below
Andy.Last edited by andy91; 27 April, 2011, 18:31.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
With Flashfxp press F4 New site put Dm 800hd in and put in the Dreambox ip in.
In Username put root
Port 21
In password put dreambox.
Hit connect,if you have set up network correctly it will connect.
Have you tried Network test in Dm800hd?If the network aint right you wont connect full stop.
Andy.Last edited by andy91; 27 April, 2011, 19:56.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
in DCC GOTO configuration put in ip of the box which you will find in network connections on dm800
user: root password dreambox look at top you should see green bar connect from pc to dm800, once this is right click on ftp at bottom you should now see your files.Comment
andy i think i am on the right track. i tried what you said it did not work but were do i get the ip address and netmask for my box. to input manually. also do i need to put ip address in pc any wereWith Flashfxp press F4 New site put Dm 800hd in and put in the Dreambox ip in.
Port 21
Andy.Comment
Been trying to tell you this from the beginning
You need to start the Dreambox,press menu,system,network.
Now set up your network.
Do you know your ip address for router??
Post that back and i will tell you what to do.
