Dm800SE Tuner failed!
  • styla
    • 223
    #16
    Originally posted by alom5
    get onto the supplier mate.................don't need this with a spanking new piece of kit.
    did you do a full scan or are you just loading channels list.
    do a full scan mate.
    Loaded a channel list mate....
    Im going to try a scan on your advice now.
    P.S Receiver is from China dealing with them and sending it back is just costly and effort although i must say ordered 3/4 dm800 pro's from them and never had a issue ever ...
    P.S check your pm mate
    • styla
      • 223
      #17
      Update:
      Manual Scan did the Trick!
      Tuner Failed issue is Gone! And All HD Channels are working solid now!!!
      So if you are having the same issue then thanks to alom5 simply run a manual scan and good luck
      • crazi
        • Mar 2009
        • 7
        #18
        after runnin manual scan were u able to update the bouquet with a flip flop bouquet or?
        Regards
        • mikk
          • 289
          #19
          settings for manual scan?
          What should the settings be for manual scan fixed dish on 28.2 ie. freq, pol, fec.. etc?
          • weedman
            • Dec 2011
            • 134
            #20
            I had this same problem with a number of images. You could do a manual scan, but that's long, I just use SGTFlipFlops bouquets and do the following...
            The solution for me was..
            1. Install a new image, set up the tuner (single, single, 28.2E).
            2. FTP over SGTFlipFlops Bouquets.
            3. Reboot your box (Full reboot, not just Enigma2/GUI)
            4. Now go back into tuner configuration, and set the tuner again (it will have changed back to 19.2E)
            5. Now it should work as normal (no reboot needed), try viewing FTA channels.
            I had this same problem, and went through dozens of images, I found that doing the above solved the "Tuner Failed" error on every image.
            I dont know why this happens, but just keep checking your tuner configuration & full restart your box. It will change the tuner configuration settings to 19.2E somewhere down the line.
            - Thanks to those who deserve them, and none to those who don't...
            - DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
            - weedman
