wrong time on 800se clone
  • _wizard_
    #76
    Well, I just got this box from madeinchina.com and it is working exelent besides the time problem. I have Peterpan image on it since I use it in Norway. It would be nice to get this fixed without returning it to china as that is rather expensive...anyone has tips or workarounds?
    • alom5
      • 1648
      #77
      Read this thread it has the fix.
      Or if you can't be arsed...download my backup....had everything working on it including the time
      • _wizard_
        #78
        Fix
        Seems as this did the trick:
        time on dm800se
        Post number 14.
        I found the addon in TS panel, instaled it and rebooted. Time has been flaless since...But only a day...Will try to report back in a day or two.
        Thx!
        • benny/9
          • 1964
          #79
          Originally posted by _wizard_
          Seems as this dit the trick:
          time on dm800se
          Post number 14.
          Thx!
          i posted the same fix on this forum and it works first class
          just remember to save the file and info to use again
          if you change the image
          Please Read Carefully!
          • DKNinja
            • Mar 2012
            I also have the time problem.
            I will try the given solutions #14 and #60
            Hopefully it will work.
            I also happen to have the frontprocessor 3.
            So it reallly seems to be a bad batch.
            If the given solutions wont work, i'll try to return the box and get one with a frontprocessor 1 in replace.
            • tosh2004
              • 100
              #81
              Originally posted by benny/9
              i have had this problem on standby for a long time
              and iv'e spent days at it testing and trying everything
              and anything, but today iv'e had everything working for
              hours by using the SERVER time.windows.com and adding a
              couple of lines of script in the settings folder using the
              latest sim 2.10 merlin3 image i will add a folder if anyone
              wants to make a test and see if it works for them all the info
              is in the doc with the file
              This the best solution I have tested with nemises image working
              Thank for this
              • flaierhoki
                • Mar 2012
                #82
                I had Nemesis 2.5 image, and just adding this config.misc.useTransponderTime=false line to enigma2 settings did the trick, did work fine. Now I accidentally updated image to Nemesis 2.6, and it doesn't work any more. Problem is, I can still add the line, but after restart the line is gone. Did all the saves and everything. I don't know what's the problem now, still keep trying. This npk + DVB time combo seems to not work to me. So, still searching answers.
                • flaierhoki
                  • Mar 2012
                  #83
                  Looks like, that I got this problem solved for now. I changed this TransponderTime setting from =false to =True, and now it seems to be working. So install this GP2 DVB time plugin and npk config file an try it out. At the moment it works fo me.
                  • h2m
                    • Feb 2012
                    Thanks a lot !
                    • lacha
                      • Jul 2012
                      I all so having the time issue on my dm800 se clone with OpnPli 2.1 beta. And I will try this fix!
                      • thagurt
                        • Apr 2012
                        the dvb time plugin does'nt work for me, the box keep losing time . after reboot of the box is the time ok
                        • messyme
                          • May 2012
                          i'm faced with the same problems...checked with supplier and was informed that it was a hardware failure...problem was i had a hdd installed in the box which was only able to record shows for about 70 minutes before the box hung up and freezes. but the moment i removed my internal hdd, clock would be operating as per normal. Puzzled as to how the hdd affects the clock settings..
                          • faithy
                            • Sep 2009
                            Main processor version 1. It has the same issue...
                            • adriankoooo
                              • 8
                              #89
                              Sorry for replying to this old thread, but I have same problem.
                              I tried everything, but it is not working.
                              DVB Time plugin - nothing, I tried all setting. NTP and Force DVB time solution => not working
                              Which is interesting too: I am unable to set manually time from ssh with date command. It just not change.
                              Is there any other way to resolve this issue?
                              I installed latest Newnigma2
                              800SE clone
