NEW mini vu duo twin tuner dreambox hybrid !?
  • tel2355
    • Oct 2012
    • 4
    #136
    I have now got another of the same box the mini vu duo from the same chinese supplier. It's working fine on boxnation and bt sports hd. The other box still doing the same on them channels but all the rest are fine. Both are running the latest openvix. Anyone got any idea's now? do use think my box with the tune failed message on those channels is faulty?
    • lincsat
      • 1228
      #137
      Originally posted by doch
      work BH 2.0.9 on X-Duo??
      Works on both the X-Duo and Mini Duo, although I use the patched Ferrari version as it appears to boot faster.
      • SpiKed
        • Feb 2013
        • 55
        #138
        Originally posted by trance
        Spiked, how are you getting on, any updates on your situation. any contact with the supplier ?
        I haven't bothered to contact them, I've just accepted that the box is dead as I've only been using it in the spare room. I did try the black hole method with usb but to no avail.
        3x Skybox F5S 1x VU+ Duo
        • trance
          • Aug 2009
          • 223
          #139
          Originally posted by SpiKed
          I haven't bothered to contact them, I've just accepted that the box as I've only been using it in the spare room. I did try the black hole method with usb but to no avail.
          I contacted them, they said to send it back ( only with ems or registered post office) . Probably gonna cost a lot to do so.
          • doch
            • Dec 2013
            • 4
            #140
            ferrari version V2 or V3??
            • btarr
              • Mar 2010
              • 21
              #141
              vu mini
              lincsat could you tell me the difference between x duo and mini duo please and ur experience with these boxes..ty
              • singingshiver
                • May 2012
                • 12
                #142
                I can't seem to get my box to flash the latest VIX image.
                I've formatted my USB to FAT32 and using build 802.
                The box just keeps booting straight into OPENPLI.
                I've tried 2 USB's neither seem to be working, Do I need to flash a new bootloader first?
                Did you get this sorted?
                My VU Mini Duo arrived today and I have setup OpenPLI to make sure box works OK. Now want to install VIX but can't seem to get this to flash. Have tried 2 different pen drives, in all 3 usb ports with no joy. Have tried original VIX image as well as Ferrari versions. Any ideas?
                • lincsat
                  • 1228
                  #143
                  The X-Duo looks like a Solo2 and the Mini Duo looks like a DM800se. The X-Duo has more space inside with the fan on the rear (so slightly quieter), The Mini Duo is slightly quicker to install the HDD. Blackhole backups are easier with the X-Duo, with the Mini Duo you sometimes have to change the kernel_cfe_auto.bin to one from a raw image
                  • singingshiver
                    • May 2012
                    • 12
                    #144
                    Just an update, I have today purchased a new usb pen drive and tried to flash vix again and its worked 1st time. It seems to 2 usb flash drives I had tried to use were not liked by the mini vu duo (even tho the box recognised then when booted up in openpli).
                    • southpaw
                      • 2233
                      #145
                      the only variants in usb stick besides size is there format type, if you can check which file type they are formatted with it may clear things up a bit for other users, right-click + properties in windose and look what "file system" it says , maybe the working one is formatted to ext3 and none working are NTFS or fat32 ?
                      • singingshiver
                        • May 2012
                        • 12
                        #146
                        It had nothing to do with format type unfortunately. The 2 none working drives were tried as ext 3, fat and fat32. The working drive was formatted to fat32.
                        Sent from my HTC One using Tapatalk
                        • stokshit
                          • Feb 2014
                          #147
                          Lombard , tried blackhole and openpli, box dont wanna know.
                          cunny , have not tried rs232 method just yet been busy last few days
                          and spiked , that makes two of us with the same issue. Hopefully there will be a fix
                          Im in the same boat as trance and spiked. I installed a hdd and the box just went into a coma. Tried to flash numerous imaged on different usb sticks on all the usb ports unsuccessfully. Ive even tried to connect the box with a rs232 cable and cant get the vu util program to connect to the box to flash. has anybody got a solution?
                          • trance
                            • Aug 2009
                            • 223
                            #148
                            Ive sent mine back to supplier, hopefully they receive it , fix it and send it back.
                            • stokshit
                              • Feb 2014
                              #149
                              Confidence is dented now im just going to try and get a refund
                              • hamilton60
                                • Mar 2014
                                Hello, I received my vu + duo mini. I want to know if I install directly VIX 3.0, or if I do an update of the bootloader before, and update security. or both at the same time? thank you for your help
