Dm800 setup guide
  • jumpinjo
    • 869
    #16
    Originally posted by gibson
    Not sure how to instal EMU via buttons though..
    connect to server and download from menu and install yellow button/addons i think
    • damiensk
      • Apr 2010
      • 201
      #17
      d/l for me ok,
      very useful
      • gibson
        • 14
        #18
        This is becoming a very usful thread.
        Next question is how do you download a channel list onto the DM800.
        Do you need a loader if not could some kind member explain in simple terms "How To."
        Thanks and again
        Best wishes from,
        Gibson.
          Green \ Yellow\ Add ons\Enigma2 settings, then choose one,or search for catseyes e2 and transfer them to box using Dreambox edit
          • jdimario
            • Feb 2010
            newby
            any one post me in the right direction for the set up tuitorial
            • gibson
              • 14
              #21
              Thanks for that BulldOg. Do you know how to load keys onto the DM 800? And could you tell me how I can do this. Thanks again and
              Best wishes from,
              Gibson.
              • kadnor
                • 78
                #22
                DM800 HD satellite
                For a DVBS2 DM 800, can i utilize the same configuration.
                I do have one antenna , one LNB.
                Have scanned W2@ @ 15.8*East, I got a list of services
                50 in all. But No audio or video.
                Where have i gone wrong in pre scan configuration.
                Thanks in anticipation,
                kadnor
                Originally posted by westkill
                are you using a motorised setup ?
                If your using DiSEqC 1.2 you will have to set-up the dish positions manually. If your usuing USALS it should be automatic.
                Here's the USALS procedure from memory (someone please jump in and correct me if I've made any mistakes)
                First make sure the dish is correctly aligned on a satellite, eg THOR 1W
                Press Menu -> Set Up -> Service Searching -> Tuner Configuration
                Choose Tuner
                ALPS BSBE2 (DVB-S2) - Press OK
                Configuration Mode: Advanced
                Satellite : THOR 1W
                Voltage Mode: Polarization
                Tone Mode: band
                LNB : LNB 1
                DiSEqC Mode: 1.2
                Use USALS for this Sat: Yes
                Longitude: Set this to the correct Longitude for your area.
                To find the correct longitude settings for your area go to the following website
                Worldwide map search, route finder and travel directions - powered by Multimap
                In the "Find a Map" box at the top left of the page, enter your post code.
                Select your country in the drop down box below it and click on the "Find" button.
                This will display a map on the screen and below the map at the bottom right you
                will see your Latitude information, example below for Post Code NW1 UK :-
                Lat: 51:31:59N (51.53319)
                Lon: 0:08:40W (-0.1445)
                you may have to miss last digit
                So in this example in the Dreambox menu you'd set
                Longitude: 0.1445
                West
                latitude: 51.53319
                north
                • kadnor
                  • 78
                  #23
                  set up guide suitable for a fixed mount, no diseqc or usals
                  Would you please study the possibility of guiding me towards
                  a tutorial for Dm 800 HD.
                  Pre scan configurations iare very critical in obtaining good results.
                  Thanks for your assistance,.
                  Cheers, kadnor
                  Choose Tuner
                  Satellite : THOR 1W
                  Tone Mode: band
                  LNB : LNB 1
                  DiSEqC Mode: 1.2
                  Longitude: 0.1445
                  West
                  latitude: 51.53319
                  north
                  • Curious123
                    • 2591
                    #24
                    You need to follow Westkill's post to configure the long/lat settings and your dish settings. Once you have done that you need to go into setup and select network and setup the parameters so that your dm800 can connect to the internet. Press the Blue so that you can download the CCcam cam to your dreambox. If you have a cline than you will need to insert that into CCcam.cfg file and ftp it to the var/etc folder on your dm800. You can download the channel settings from the image server or Google for your own and use a program called Dreamboxedit to send them to your dm800.
                    • adrianok
                      • Oct 2010
                      #25
                      DM800 looping after changing skin, any easy fix? Re-Flashing would be a pain.
                      Also, how do i open the graphical EPG for the channels i have?
                      I've been at it for hours before the looping thing,
                      Thanks in advance
                      • hanuman99
                        • Feb 2012
                        • 4
                        #26
                        Originally posted by jumpinjo
                        try this bud
                        Just got my DM800 HD. Will get this a try. Wish me good luck.
                        • mtv1
                          The Stig PT
                          • 4413
                          #27
                          welcome to DK matey _ most folf say hello here Introduce Yourself bot welcome all the same
