Dish overturning problems, Help please..
  • setfiretorain
    • Jul 2010
    • 934
    #16
    Can I not tweak it from the box, Because I Don't see how the problem has been caused, I go to positioner setup in dreambox and I am able to tweak west and east and get a SNR. ?
    '"If you can't make decisions in life, you're a bloody menace. You'd be better becoming an MP!"
    Quote from Mr Shankly, YNWA, JFT96
    Sat Boxes
    Spiderbox 7000 HD with " gift "
    Dreambox 500s.
    Dishes
    1.1 Motorised triax satellite dish single LNB.
    Sky minidish self fitted.
    • setfiretorain
      • Jul 2010
      • 934
      #17
      I'm gonna do a factory reset on the box, Set up the Tuner again and then tell you guys how I get on !
      Sat Boxes
      Dreambox 500s.
      Dishes
      • owenb
        • 703
        #18
        make sure u know ur long and lat before u reset mate
        • plonker
          • Mar 2009
          • 18
          #19
          hi it sounds like your dish as moved
          • setfiretorain
            • Jul 2010
            • 934
            #20
            Ok, I did it and it didn't make no difference, ive scanned for channels and its picked up nothing... What is up with it, will i need to get on my roof and adjust dish or what's up ? anyone please ?
            Sat Boxes
            Dreambox 500s.
            Dishes
            • owenb
              • 703
              #21
              when u ran the wizard mate did u defo enter correct long and latitude for your area? if not yeah u need to get on roof and manually put dish to 1w
              • setfiretorain
                • Jul 2010
                • 934
                #22
                how would I find out my long / Lat ?
                Sat Boxes
                Dreambox 500s.
                Dishes
                • RuberDuck
                  • 1724
                  #23
                  with this
                  Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
                  • setfiretorain
                    • Jul 2010
                    • 934
                    #24
                    Address: l5 1tw
                    Latitude: 53.4298?
                    Longitude: -2.9662?
                    Satellite: 91W GALAXY 17 (G-17) | NIMIQ 1 | NIMIQ 2
                    Elevation: -7.5?
                    Azimuth (true): 268.4?
                    Azimuth (magn.): 271.4?
                    Is the results I got, what would the long / lat be for this.
                    Sat Boxes
                    Dreambox 500s.
                    Dishes
                    • RuberDuck
                      • 1724
                      #25
                      your long and lat are
                      Latitude: 53.4298 north
                      Longitude: 2.9662 west
                      • Curious123
                        • 2591
                        #26
                        I would send it to 1W Thor BBC World Service and check if you are still getting a picture. If you are not getting any picture then everything else will be out of alignment.
                        • steve29662
                          • 18
                          #27
                          Just a note on Latitude: 53.4298 north
                          on dreamboxes 800hd you must start with 360 on the longitude then deduct 2.9662 = 357.033 enter this in your longitude.
                          hope this helps.
                          • setfiretorain
                            • Jul 2010
                            • 934
                            #28
                            Thanks for the long lat help, and im not picking out up on 1 west, You think its best to hook say a technomate up and manualy keep moving dish till correctly aligned with 1W then hook it back upto dreambox and scan in 1W followed by others. ?
                            Sat Boxes
                            Dreambox 500s.
                            Dishes
                            • Wingnut
                              • 376
                              #29
                              mate when u tweaked last time and got snr on sky sports 1,u had to then save that position,say postion 1 then press exit,then it will say , zap back to service before tuner setup, dont select yes as u did before but select NO,,then go to tuner configuration and go to 28.2e,and scroll right to the very botton and were it says use usals for this sat select no,then store position as number 1 and press ok, u wud then have been able to view 28.2e ok, u cud have done this for the rest of ur sats to get them going also,
                              • setfiretorain
                                • Jul 2010
                                • 934
                                #30
                                Thanks !
                                hmmm oh. Didnt no !
                                Thanks anyways, see what i can do from here on in.
                                Sat Boxes
                                Dreambox 500s.
                                Dishes
