Noobs guide to patching your Technomate
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • Aug 2008
    • 5611
    Guide for the newbies.
    Heres how to load the patches.
    • Download the relevant patch and extract.
    • Download the relevant loader and extract.
    • Connect your receiver to the pc via rs232c cable.
    • Choose the correct com port.
    • Leave the receiver on standby.
    • Open the loader and select the software tab.
    • Press browse and find the extracted patch.
    • Press ok then start then wait.
    This will take a few minutes. Thats it. The same things need doing for softcams but make sure you use the keys tab. Everything else is the same.
    USB, By Benny/9
    FIRST ALWAYS MAKE SURE YOU USE THE CORRECT PATCH FOR YOUR MODEL
    there are various models and only the correct patch will work or even load on your model
    • Download the correct patch for your receiver.
    • Open the zipped folder and take the patch out ready to transfer the patch onto your usb memory stick.
    • Insert your usb memory stick in the usb port under the front flap.
    • Turn the receiver on ready to load the patch then press the usb button on your remote.
    • on the next screen go to data transfer and click>OK.
    now you will see a panel with the patch on it, it will highlight, [for patching].
    press ok on the highlighted patch then it will load and when it gets to 100% and has loaded, and the receiver has re-booted [turned off and on again] and the channel opens, remove your usb memory stick. you have now loaded the patch and your channels will now open.
    you also load softcams/channel lists/official software etc:in exactly the same way by selecting
    the item you want to load.
    Note: if scrambled channel appears on channels which should open; wait a few minutes. This will enable the auto update to kick in.
    Hope this is found helpful. Sadiq999uk and Benny/9
    Last edited by .: JaCkPoT :.; 12 December, 2008, 00:00. Reason: USB added. thnx to benny/9
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
  • tee23uk
    • 10
    • Download the relevent patch and extract.
    • Download the relevent loader and extract.
    hi i have the technomate 6900 but all still scrambled im using s/w version 6.53p june 27th on cass menu can you advise me if ive got something wrong thank you
    • titian40
      • Oct 2008
      • 30
      Thanks for help. The AU delay has fooled me before!
      • .: JaCkPoT :.
        • Aug 2008
        • 5611
        i take it your sorted now.
        ___________________
        DM800s HD
        Openbox S10
        TM500
        DM500s
        Maxx 110cm Dish
        • dundeejim
          • 27
          can i use a usb flash pen instead m8?
          • .: JaCkPoT :.
            • Aug 2008
            • 5611
            If you got usb receiver then ofcourse.
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
            • dundeejim
              • 27
              the patch wont go on the pen
              • .: JaCkPoT :.
                • Aug 2008
                • 5611
                You have to extract the file first, the box cant unzip or extract. Try that.
                ___________________
                DM800s HD
                Openbox S10
                TM500
                DM500s
                Maxx 110cm Dish
                • dabba
                  • 8
                  what is the difference between patching and softcam ?
                  there appears to be new for both almost daily, do they need patching daily ?
                  • .: JaCkPoT :.
                    • Aug 2008
                    • 5611
                    A patch is firmware/software to help your receiver work which has keys already in it but when they expire they need to be updated to thats what the softcam does.
                    ___________________
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    Maxx 110cm Dish
                    • dundeejim
                      • 27
                      yes when i try to extract say something about cant do it
                      • dabba
                        • 8
                        and do the soft cams AU?
                        how often on average do they req updaing ?
                        • .: JaCkPoT :.
                          • Aug 2008
                          • 5611
                          Keys au very regularly on some channels and on others after a period of time.
                          ___________________
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          Maxx 110cm Dish
                          • dadadere57
                            I ve just joined this website. I have no experience of satelitte receiver . How can I download technomate loader for my 6900 Combo?
                            Dadadere57
                            • dundeejim
                              • 27
                              go to the technomate download select ur box and download patch
