Guide for the newbies.
Heres how to load the patches.
This will take a few minutes. Thats it. The same things need doing for softcams but make sure you use the keys tab. Everything else is the same.
USB, By Benny/9
FIRST ALWAYS MAKE SURE YOU USE THE CORRECT PATCH FOR YOUR MODEL
there are various models and only the correct patch will work or even load on your model
now you will see a panel with the patch on it, it will highlight, [for patching].
press ok on the highlighted patch then it will load and when it gets to 100% and has loaded, and the receiver has re-booted [turned off and on again] and the channel opens, remove your usb memory stick. you have now loaded the patch and your channels will now open.
you also load softcams/channel lists/official software etc:in exactly the same way by selecting
the item you want to load.
Note: if scrambled channel appears on channels which should open; wait a few minutes. This will enable the auto update to kick in.
Hope this is found helpful. Sadiq999uk and Benny/9
- Download the relevant patch and extract.
- Download the relevant loader and extract.
- Connect your receiver to the pc via rs232c cable.
- Choose the correct com port.
- Leave the receiver on standby.
- Open the loader and select the software tab.
- Press browse and find the extracted patch.
- Press ok then start then wait.
USB, By Benny/9
- Download the correct patch for your receiver.
- Open the zipped folder and take the patch out ready to transfer the patch onto your usb memory stick.
- Insert your usb memory stick in the usb port under the front flap.
- Turn the receiver on ready to load the patch then press the usb button on your remote.
- on the next screen go to data transfer and click>OK.
i take it your sorted now.
