Beside right hand corner of the HDD in that photo theres 3 in a row you want the one nearest the drive.
VU Duo Red Light
It's beside the three regulators, (which if the cap change doesn't work will be the culprits,but that's a whole different problem in itself), sorry but I cannot get down to the level required in the pic to be 100% sure which exact cap it is.
But I gave the name C807, so any tech can pick it out once they have the board in front of them.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Yes a capacitor will have a positive and negative side, just make sure you follow the alignment correctly which is indicated by a line on the side of the cap.
Here is a full picture tutorial, (thanks to al3z77), on where the cap is and how to replace it:
ImageShack? - Online Photo and Video Hosting
Follow the link to the first pic and then scroll through the next 13 images, on the right hand side click next..I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Will be doing this at the weekend, Can it be soldered inside the casing or does the board need to be removed completely?
Better to desolder out of the case with a solder sucker from under the board. However,you can do the job without lifting the board off the back plate if you use a thin solder tip but take care not to damage the solder tracks. Use a small long nose pliers to lift the cap if you are not using a solder sucker.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Tried several power supplies, Even took one out the Sky box and my printer to test and it didn't work, Same red light top corner
Not yet and no, will try replacing the cap this weekend if that doesn't work will look at the PSU
