Since the clocks went forward the epg is now an hour out, have tried reformatting stick in computer and then reloading epg but it's still one hour behind, can anyone help?
Can't solve epg being 1 hr out??
Realistically the box is programmed into the world clock any changing accrue from menu will have to be forced by technical way.Tools owned: Hammer, Chisel, Crowbar, Punch, Chainsaw, Cutter and Brain!!!
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
The time is correct on the system and the epg is off by an hour, altering the time by an hour or even two makes no difference so the epg appears to be separate from the system clock so I figure the issue is with the xmltv file but I can't find it on my HDD to look at it, just did an update and looked at the files again and there is nothing with a modified date of today - what is the file called and how do you edit it?Last edited by Slywalker; 31 March, 2014, 17:41.Comment
