Page 38 of 94 FirstFirst ... 2833343536373839404142434888 ... LastLast
Results 556 to 570 of 1400
  1. #556
    Here is information about newest update to autocom. So we must wait, coz they want to add new security for program.
  2. #557
    Aug 2009
    Yeah, 1xmounth more waiting.
    Last night i readed this message from autocom.se.
    Sorry, was my bad.
  3. #558
    Jul 2010
    GB
    Anyone knows what is the role of the XC68HC58 MCU inside the Autocom interface?
  4. #559
    Top Poster + andy99's Avatar
    Aug 2009
    EUROPA
    Quote Originally Posted by fifas2010 View Post
    Hello DK?s
    How to update your Autocom CDP....
    To update your Autocom CDP interface to Realise 3, 2010
    - Hardware ID and key to install on PC
    - Hardware ID and key to install on Pocket PC
    - dump to ATtiny
    - dump to 29F800
    Pass in PM ):
    hello need pass for dumps thanks
    Abritus AK400 BDM100 BMW-EXPLORER Beprog+ CLIP CarProg ETL ELM324 FVDI IDS J-Link GALLETTO3 SMOK K-SUITE Lexia3 MERCEDESINSTRUMENT MPPSv16 MVP ORANGE5 StarC4 TANGO UPA XprogM X-TOLL ZedBull
  5. #560
    DK Veteran Amine13's Avatar
    Aug 2009
    HI,
    Any idea about what Bluetooth module can be fitted inside PCB of Autocom, I have one which the bluetooth module seems to be damaged.
    BR.
    Just start, and all come itself!!!!!!!
  6. #561
    Aug 2009
    Get out PCB from the case, and try after.I think you have not antenna conected to main-board(without conector)
    If working like this, solder an antena to the BT module.
  7. #562
    Aug 2009
    Quote Originally Posted by flavyus1987 View Post
    Thanks for your reply.
    I have antenna and it was connected; the unit is recognized and even connected; but when the communication starts, then the unit is self disconnected, tested with other unit, and works fine..
  8. #563
    DK Veteran chrismoore02's Avatar
    Jul 2011
    England
    Thought i would give you an update, i have replaced the resistors R74 and R75 for 390ohm and now the unit can scan 2001 ford ka ok.
  9. #564
    meteor80's Avatar
    Dec 2009
    Poland
    Hello.
    I have problem with autocom.
    It communicate with Ford and other brands, but it don't communicate with Opel Astra H with airbags and central electronics.
    It is SW CAN. Does someone know how to repair that?
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  10. #565
    Aug 2009
    EUROPA
    Hello DK?s
    - dump to ATtiny
    - dump to 29F800
    Pass in PM ):
    Pass please
  11. #566
    Mar 2011
    HI guys I have problem with MB C-Class W202 1996 year 2.0 benzina I can not connect with AutoCom ECU, Airbag, SRS, ABS...
    Have you any Idea fot this solution ???
  12. #567
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    How to remove AUTOCOM 2011.1?
  13. #568
    Nov 2009
    Pitesti,Romania
    uninstall and clean registry if you want to install 2011.3
  14. #569
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by djcristi View Post
    in detail
    clean registry?
  15. #570
    Nov 2009
    Pitesti,Romania
    clean autocom entrys from reg
