more detail please?.......idiots guide for someone never done this before.
Download ccleaner and run it, it will clean lot of unneeded registery keys.
Just start, and all come itself!!!!!!!
hello,
I have some problems with autocom:
was everything okey,but after i fail to connect to ford mondeo 2004,i see no LED lights on at all,device dead.
I have oki chip inside,was able to do everything on fords before,but now,not work on all cars...try to reinstall software no look,then i try to plug inn cable to usb i can see table(windows.xp)..unknown device...maybe someone have this problem with autocom?thanks.
i think your hardware is dead, check the voltage regulator near the capacitors
I got one time same fault, and guess what; Pin 4 or 5 (ground pins, don't remember which one ) was inclined inside OBD2 female blue connector of autocom, so no communication because simply no ground. made it straight, then all went fine;, just take plug, and see if all pins are straight.
Good luck!
yes, you can also measure inside the autocom , if it get's power from obd
I have power from car,but no power from pc usb.Normally then connect autocom to usb,pc recognize device and show Vci device conected,and autocom LED on(red,then not connected to car)....but my autocom complettle dead then i try connect to pc(no LED on)....ant pc shows Unknown device connected,so nothing working even then i try to connect to car,.....looks like no drivers for autocom,but when i try another autocom(good one) everything works,so for sure not software problem,something wrong with pcb board(top one with LEDs).
Looks like the hw of your autocom is dead, for the price it costs, don't bother yourself to fix it, better get a new one !
Regards.
I'm impressed so far with mine, hasnt let me down on anything in the list from older voyager abs to newer ford airbag.....
j'ai instalaler autocom 2011/3 ala fin de l'instalation il me demande l'activation du soft j'ai fait par usb j'ai u un fichier d'activation je ne s'est pas coment fait votre aide merci
English ?
Sent from my Galaxy Nexus using Tapatalk 2
Anyone found a fix for BMW's not working yet?(E60/65/39/90)
Thanks OBD
