Page 17 of 66 FirstFirst ... 7121314151617181920212227 ... LastLast
Results 241 to 255 of 982
  1. #241
    Aug 2008
    yes you should add that capacitor
  2. The Following User Says Thank You to tango For This Useful Post:
    trinicolin (23rd April, 2017)
  3. #242
    Dec 2010
    Brno, Czech Republic
    Hi all
    I try to read mcu HC08 2J74Y (dashboard nissan terrano2) using carprog + A10. EEPROM i can read write OK, but the FLASH part no. Carprog make initialize boot loader and read nothing, when i try write, carprog say erase failed.
    Can someone help me fixt this problem?
    Thank a lot.
  4. #243
    3inferno3's Avatar
    Nov 2014
    Europe
    In codecard website you cay buy A20 adapter...and unsolder 2j74y...I did it with this solution and works well 20170322352.jpg this is my clone ver 8.21 and he do 95% things
  5. #244
    Dec 2010
    Yes i know, but i think the problem is inside carprog. A20 adapter cant solve my problem.
  6. #245
    3inferno3's Avatar
    Nov 2014
    Europe
    Did you change hc125m? SS14 capacitor? 22uf tantal.capac.?and 020 resistors? if You will fix things like in thid case your clone will work.look my pictures-2j74y right top corner read progres and 0D66J in circut airbag20170316336.jpg20170322353.jpg20170322350.jpg
  7. The Following User Says Thank You to 3inferno3 For This Useful Post:
    j0anita (24th April, 2017)
  8. #246
    Jan 2016
    Quote Originally Posted by 3inferno3 View Post
    can you give more details, and make a pic from your pcb ? where are these componenst that be changed ?
    make please a list
  9. #247
    Dec 2010
    Tank you for you help.
    Yes i change all 4 IC to 74HCT125D. But the capacitor and rezistor may be not. (SS14 is capacitor or diode?)
  10. #248
    Jan 2016
    some people says 74HCT125D is correct and others says 74HC125M is correct !! which one is true?
  11. #249
    Dec 2010
    I dont know. I change for 74HCT125D, but motorola mcu and 24xx dont work. But i my case is another one problem.
  12. #250
    3inferno3's Avatar
    Nov 2014
    Europe
    Sorry not capacitor SS14 ONLY diode.after when you swap this diode you can do programing and other things without 12+ except motorola (when need 12+) I use HC125M from texas instruments and every carprog work great..do not use 125d!!! it is bad solution.. Yes i will do few pic PCB and I will share here ok? maybe today..
  13. The Following User Says Thank You to 3inferno3 For This Useful Post:
  14. #251
    Dec 2009
    My clone comes with 74HCT125D from Philips (?). Please upload pics with some info of your mods. Thanks!
  15. #252
    Jan 2016
    Thanks mate
    can you also read motorola HC05 ? i tried to day atempt 1.2.3...5 and nothing ! I have also hct125D on board...maybe after replace can i also read hc05
  16. #253
    3inferno3's Avatar
    Nov 2014
    Europe
    Without problem motorola HC05? Which mask??? x32? watch on my A10 on picture where is programing HC08 0J66D. For example one wire 5v+ (red) I soldered two more wires..and i did more wires like that.You can programing in circuit but remember some legs must be up! First You have to check which solution work..Unsolder 125d its not good..always work 125M from TI or FAIRCHILD. cHEERS
  17. #254
    Jan 2016
    I have to day tried to read ( immobox of Golf3 in circuit ) HC05B6 mask 0F10V 4x13 legs, I cant see any info in de manual about cutting of some legs from pcb.
    i will order 125M from TI
  18. #255
    3inferno3's Avatar
    Nov 2014
    Europe
    Immo box golf 3 has PLCC52 motorola..You can't lift any legs from PCB Beter unsolder it and you should use xprog hc05 PLCC52 adapter and will be fine try and You will see bro
