Can this cable be used to download vcds on it's a old vag tacho it's worth a try asking cheers if so how do I go about it thanksIMG_4924.JPG
Mate, why don't you want to just buy a quality cable and enjoy it?
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
"Classic" interface:
http://www.obd2cartool.com/vagcom-16...version-p-1266
"HEX-V2" interface:
http://www.obd2cartool.com/atmega-va...t-skoda-p-1492
* MK100;
It's not the same as you posted previously some posts ago. It's internals are different. Yours = Aliexpress = crap. This one is Atmega162 = good.
Yours case is better, I agree. But internals are crap.
Forget the disk. You need Kolimer's stuff.
* MK100;
Here you can see how it happened (see file attached).
In two words: after trying to chang byte 27 from 00 to 04 it has changed acording to coding debug file to D0. After this I got a lot of faults in BCM but haven’t time to find out the reason. In couple a days I'v get back to the issue and saw completely wrong coding in BCM!
41190B218D260FC1458901C132010EC54E7E9189426E8661E5 85C80E0142 instead of
40180A208C250EC0448800C031000DC44D7D9088416D8560E4 84C7040041
I have exatly the same wire you likned on obd2cartool but I have a lot of difficult to properly program this wire. This beacause when I connect the wire to car the led doesn't turn on. I have to connect and disconnect many times then the led turn on red then green. And the wire after few times used does not work anymore. Can you tell me in witch way you program this wire please?
Read this topic. There are two methods for updating the vcds cable with Atmega 162.
http://obd2-diag.blogspot.com/2017/0...al.html?q=vcds
Hi all,
I'm having trouble starting V5 loader under win xp, only splash, vcds program not starting, i think loader probably requires higher version of dotnet then 4.0 because under win 7 there are no any problems. Can somebody confirm this.
Try to start loader 3 -5 times, finally VCDS will start![]()
Yes you are right, but it's definitely better under win 7, it starts every time
