Page 54 of 178 FirstFirst ... 444495051525354555657585964104154 ... LastLast
Results 796 to 810 of 2663
  1. #796
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    It seems they change token politic faster then someone his underpants...
    Each day something new...
    I'll hope that they don't get a power failure on their server... And lost all informations about their own token politic...
  2. #797
    Jul 2010
    Quote Originally Posted by p1et View Post
    I have 1 token / day from beginning and tool got it's expire time. After 180 days I needed to re-activate for 70 usd for next half year and I stil have 1 token per day. So I'm being fcked
    I had this problem even after the purchase. I contacted my seller and he took care of it. It took about 10 days, then I had 2 tokens a day
  3. #798
    figani's Avatar
    Feb 2018
    Translate in normal language, everybody of us has to fight with them each day to get what he has paid for...
    We should also make business with them, when server not answer right now... Press PayPal dispute buttons... And all at the same time...
  4. The Following User Says Thank You to figani For This Useful Post:
    rob h (20th September, 2018)
  5. #799
    Feb 2014
    I don't know about the extra tokens, but if you get 1 token each day and you have to reactivate every 180 days, then you should contact CGDI or your beloved dealer and make them fix this and put you on one of the existing plans - A or B.
    This extra tokens for additional tools seems too shady, still. It should be explained separately what happens if you have plan A and get a second machine, and if you have plan B and a second machine.
  6. The Following User Says Thank You to autoTkey For This Useful Post:
    figani (21st September, 2018)
  7. #800
    figani's Avatar
    Feb 2018
    for them it´s shady OK... so they can tell you one story and me another story...
    1000 of coustmers and 1000 of storys...
    the shit will start to smell when the server get not enough electricity...
  8. #801
    May 2015
    After newest update tried to renew med17. 7 and could not do it. It worked before
    Sent from my SM-G950U using Tapatalk
  9. The Following User Says Thank You to Nymike For This Useful Post:
    yugo45 (22nd September, 2018)
  10. #802
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by Nymike View Post
    That is not good, I hope they will fix that .
  11. #803
    grzyb26's Avatar
    Jan 2012
    CG-MB BenzMonster V2.7.2.0
    (2018.09.20)
    1. Fixed the problem that read EIS failed when 209/211 collection with key.
    2. Fixed the problom that 209 sync ELV and 169 write ELV display is not clear.
    3. Fixed the problom that the K-line EIS is enabled successfully, but the display fails.
    http://www.cg100iii.com/benz/BenzMonster_Setup.exe
  12. #804
    Jun 2017
    US
    How do we know what models it can do by obd and what models we need to do on the bench? C250 2013 can we add key by OBD? Can it do all keys lost OBD on this model? Thank you.
  13. #805
    figani's Avatar
    Feb 2018
    maybe for this operation we´ll in future also need some tokens or blue points (right next to the token diamants)...
  14. #806
    hello
    is there a problem with new update for w204 AKL, it is always failing
  15. The Following User Says Thank You to tech111 For This Useful Post:
    yugo45 (28th September, 2018)
  16. #807
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    yes and W212 too it keeps failing to add key, when it is supposed to save the collected file for password computing it always asks it i inserted the working key on the EIS
  17. The Following User Says Thank You to koolstuff For This Useful Post:
  18. #808
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    dont think will ever be as good as vvdi
  19. #809
    Jul 2018
    CGDI Can add the original bga key?
  20. #810
    yes , in fact i used to have the vvdi , recently bought the cgdi , it cant get all passwords for 7g , also
    today i tried w203 this time it was able to add key without removing the EIS from the car and car key was nec one , it took around 20 mns
  21. The Following 2 Users Say Thank You to tech111 For This Useful Post:
    bocaje (28th September, 2018), doctore (28th September, 2018)
