Page 196 of 295 FirstFirst ... 96146186191192193194195196197198199200201206246 ... LastLast
Results 2,926 to 2,940 of 4423
Thread: VVDI PROG
  1. #2926
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by daxxer View Post
    clip are mostly for lazy people only, but i understand....it can save lot of time and work
    And that matters @ roadside work. IT isn't funny to search for a fallen Spider (8 legged eeprom) on the black asphalt
  2. The Following User Says Thank You to PocketHero For This Useful Post:
    conbee70 (28th February, 2019)
  3. #2927
    Dec 2010
    Default ezs adapter
    Hello colleagues, someone who uses adapters for ezs.
    I just bought them, and the first test w203 and I have this problem.
    Has anyone tried it?
    Thanks for your time
  4. #2928
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Has nothing to do with the adapter, except the bad contact. Release it, put it back, try again. Nothing dangerous.
  5. #2929
    Apr 2014
    Quote Originally Posted by jaelgti View Post
    Look at the chip type on the other side of the PCB. Post picture.
    Sent from my SM-G930F using Tapatalk
  6. #2930
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by trinicolin View Post
    on other side moostly 2J74Y
    many thanks to friend kevfield
  7. #2931
    Jun 2017
    Ukraine
    Hello. Soft 4.8.0 BMW CAS4 1N35H chip not read and write after unlock success, force unclock too:
    [2019-03-01 08:50:53] : Start communication...
    [2019-03-01 08:50:53] : Chip is not crypt FE
    [2019-03-01 08:50:53] : End communication...
    [2019-03-01 08:50:53] : Operation success
    [2019-03-01 08:50:56] : Check Device...
    [2019-03-01 08:50:58] : 12V Power Adaptor connected
    [2019-03-01 08:50:58] : Initialization device...
    [2019-03-01 08:50:58] : Initialization success!
    [2019-03-01 08:50:59] : Initialization chip...
    [2019-03-01 08:50:59] : ID 0N35H 0XCC95/1N35H 0XCC95
    [2019-03-01 08:51:00] : Chip is crypt,this operation needs to decrypt
    Any ideas?
  8. #2932
    habbyb's Avatar
    Jun 2010
    Romania
    adapters work perfectly , check connection .
  9. The Following User Says Thank You to habbyb For This Useful Post:
    WinWoj (1st March, 2019)
  10. #2933
    Dec 2010
    Quote Originally Posted by PocketHero View Post
    Thank you very much for your cooperation, before publishing, I have connected and disconnected several times, cleaned the pcb and verified that the pins make contact.
  11. #2934
    Dec 2010
    And on the other side it's the same 4j74y
    And say that the module works correctly.
  12. #2935
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    try to preheat the mecu which you want to read...its probably almost dead
  13. #2936
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Makes nothing, but try tó push down the clip when reading. Sometimes it helps.
  14. #2937
    Apr 2014
    Zoom this area.
  15. #2938
    Dec 2010
    Thank you very much for your interest colleagues
  16. #2939
    WinWoj's Avatar
    Jan 2012
    ECU City
    Somebody used fvdi to read older ezs from W208, W210 etc? xhorse doesnt produce adapters fro this ezs, but mcu cable could do this two Motorola MC68HC05X32 witfout desoldering, or only lifting reset leg?
  17. #2940
    Jan 2018
    can someone help me? to read tricore with vvdi prog? in suzuki swift sx4
    please, thnks
    Sent from my Redmi 4X using Tapatalk
