Page 102 of 178 FirstFirst ... 25292979899100101102103104105106107112152 ... LastLast
Results 1,516 to 1,530 of 2663
  1. #1516
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by u.s View Post
    Try this mate.....
    Thanks a lot but unfortunately this rubbish IR code reader also broke when I unplugged USB when software was working. Every day something got messed up and I still don't have working CGDI software, omg
  2. #1517
    Apr 2016
    maybe my problem that i trying to extract pass from motorola based ezs XXX5450708, today ezs nr 2, same number obd method error collecting, platform error collecting, 120 ohm resistance between can exist
  3. #1518
    Jul 2018
    Default zdr
    Здравейте някой знае ли дали можете да замените ezs на W210 и как работи? с cgdimb
    Здравейте Някой ли Дали мож EZS на V210? и как работи здрави някои да замен ите ezs на v210? и как работно Здравейте някой знае ли дали можете да замените ezs на v210? и как работи
  4. #1519
    88diablo's Avatar
    Jan 2010
    I have a 2015 Sprinter W906 that CGDI says the file type is incorrect when I try to load a file read by VVDI prog. Ive read that I can copy and paste to make the filke work but im not sure which part I need to move as it just keeps saying file type incorrect. NOW SOLVED
  5. #1520
    Apr 2019
    Quote Originally Posted by 88diablo View Post
    I read the eis for one Sprinter 2014 year with Xprog
    After that try this, open file in Hex editor.
    Copy paste lower half, starting where data appears,all the way to the top. Then load IT with cgdi and you will see the passwort.
  6. The Following User Says Thank You to niksata90 For This Useful Post:
    p1et (10th August, 2019)
  7. #1521
    Apr 2019
    Someone know how to read the eis for W169 on bench with CGDI? ( I try with gateway simulator and with obd2 cable but don't work)
    I can read the dump with Xprog, but when I load the file in CGDI there don't write keys positions... I need to know which keys are already used.
  8. #1522
    Quote Originally Posted by niksata90 View Post
    Throw your dump
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  9. The Following User Says Thank You to EduardNN For This Useful Post:
    niksata90 (15th August, 2019)
  10. #1523
    Oct 2016
    France
    i have same problem,i did make key for w169 last week,i use vvdi prog for dump,and if you dont see key possition you can use SKC,with skc you can see keys possition and after use cgdi to make key
  11. The Following 2 Users Say Thank You to barho67 For This Useful Post:
    Freezzby (29th September, 2020), niksata90 (15th August, 2019)
  12. #1524
    Apr 2019
    Quote Originally Posted by EduardNN View Post
    Throw your dump
    https://mega.nz/#!DtVQHCoL!Dsccpay5w...LCkfraWbuyyk24
  13. #1525
    Apr 2019
    Quote Originally Posted by barho67 View Post
    Thank you!!!
    I tried with new option "IR read Eis data"
    You can give 12v and gnd on the Eis and after that put the IR key.
    With this method you can see which keys are used too, but I don't understand how can I renew the EIS. Do you know how can I do that?
    Regards
  14. #1526
    SKC Simon Key Calculator
    Don`t forget to use
  15. The Following User Says Thank You to EduardNN For This Useful Post:
  16. #1527
    Apr 2019
    thank you!
    Do you know how can I renew the Eis?
    Regards
  17. #1528
    Why do you need this? What do you want from EZS?
    Don`t forget to use
  18. The Following User Says Thank You to EduardNN For This Useful Post:
    niksata90 (16th August, 2019)
  19. #1529
    Apr 2019
    I just want to know are this possible for W169, because when the original EZS from the car is damaged i must to renew one other second hand EZS (with the same part number) and after that to save in him the EZS information.
    In my situation now i made keys and everything is ok. But when i need to change the eis i must to know how to do that, because i can't read the eis with cgdi mb and I can't renew it.
    Regards
  20. #1530
    All manipulations to zero and register EZS are done on the IR channel.
    Don`t forget to use
  21. The Following User Says Thank You to EduardNN For This Useful Post:
