Page 219 of 245 FirstFirst ... 119169209214215216217218219220221222223224229 ... LastLast
Results 3,271 to 3,285 of 3668
  1. #3271
    Feb 2022
    Quote Originally Posted by r4nd0mize View Post
    Your problem basically is the basic setting itself. Sometimes it's tricky. But missing basic setting is definetely NOT related to anything inside the coding. So you should focus on why the basic settings fail.
    If you want the coding to be checked. Let us/me know. If you have doubts about your coding it must have a reason (where is it from?). To verify if it is accurate/correct, it needs more info about the vehicle anyways. All I can say by now is, that it looks good for a left hand drive, smaller engined vehicle (petrol or small diesel), with tire pressure monitoring on. If that is the case you should not worry about that.
    Thank you for your reply.
    I too believe the coding is correct, but wanted to ask.
    Could it be a problem that the address is not aligned to be able to do the basic settings?
    I want to point out that it only fails when trying group 026.
  2. #3272
    Apr 2021
    Well, puuuh, again,... this is in first case definetely a basic settings problem. In the (second) video they are using a super old VCDS version and it is absolutely freaky what they are doing at all.
    Usually it only needs brake pressure sensor basic settings, acceleration cluster (lateral, longitudinal, yaw rate, in some cases only yaw and lateral). Doing valves is very rare and only necessary if hydraulic was disconnected from electronic. Which is like never the case as only superfreaks disconnect them for repair purposes.
    But what do you mean with "the address"? The abs has to be mounted correctly and the car has to stand flat - otherwise forget about doing basic settings. And even if it accepts not being correctly mounted, you have wrong basic values.
  3. The Following User Says Thank You to r4nd0mize For This Useful Post:
    aolvera (7th February, 2022)
  4. #3273
    Oct 2017
    Default MK5 2008 CODING LOST DUE CLUSTER CHANGE
    1K0 907 379 AD
    LHD
    STANDARD
    No start stop
    No hill control
    disk size not sure
  5. #3274
    Feb 2022
    Merhaba arkadaşlar,
    ABS ünitem sadece 000000 kod gösteriyor. Ayrıca sistemde hata kodları mevcut. Yeniden kod girmem gerekiyor. Yardımcı olur musun?
    Araçla ilgili detaylar:
    Skoda Octavia 2012
    1.6TDI CAY Motor
    Manuel Şanzıman
    SET düğmesi mevcut
    ASR düğme mevcut
    PLA 2.0 mevcut
    Yokuş Kalkış Mevcut
    Sol taraf sürücü
    VIN: TMBBT61Z4D2011724
    Parça no.: 1k0 907 379 BL
  6. #3275
    Jul 2010
    Hello
    need also long coding
    Golf v 1.9 tdi
    LHD
    No Start Stop
    1K0907379 AD
    ESP MK60EC1
    WVWZZZ1KZ9M293211
    Thks
  7. #3276
    Apr 2021
    Quote Originally Posted by zuco1989 View Post
    1K0 907 379 AD
    LHD
    STANDARD
    No start stop
    No hill control
    disk size not sure
    113B200D09230003880D04E7902000413000
    You forgot to mention TPMS. So I turned it off.
    After your cluster change, make sure you adapted it to the original VIN that is in you picture. Otherwise this coding will not work because you have to provide the VIN from scan, not from sticker in booklet or chassis.
  8. The Following User Says Thank You to r4nd0mize For This Useful Post:
    zuco1989 (6th February, 2022)
  9. #3277
    Apr 2021
    Quote Originally Posted by denizoto62 View Post
    Merhaba arkadaşlar,
    Skoda Octavia 2012
    1.6TDI CAY Motor
    Manuel Şanzıman
    SET düğmesi mevcut
    ASR düğme mevcut
    PLA 2.0 mevcut
    Yokuş Kalkış Mevcut
    Sol taraf sürücü
    Apart from not using english (board language), this is a very good request. Everything important mentionend. Especially the fact, that you mentioned PLA 2.0 because that makes special settings. But what you forgot is engine start stop, so I turned it off.
    113B201C092300FB881204E6901D0041350150
    Very important: because of PLA 2.0 this car should also have bidirectional wheel speed sensors at the rear axle. I took care of it. But please make sure after coding there is no electrical failure regarding wheel speed sensors when you read error codes. And also, very important, make sure in measurements, that when you drive forwards they also show forwards and not the other way round. If any of that is not ok, tell me so I can fix it.
  10. The Following User Says Thank You to r4nd0mize For This Useful Post:
    denizoto62 (5th February, 2022)
  11. #3278
    Apr 2021
    Quote Originally Posted by sepistar View Post
    Hello
    Golf v 1.9 tdi
    LHD
    No Start Stop
    1K0907379 AD
    ESP MK60EC1
    WVWZZZ1KZ9M293211
    Thks
    You did not mention TPMS and transmission type so I did TPMS off and transmission manual.
    113B200D092B00FD880D04E5901A00413000
  12. The Following 2 Users Say Thank You to r4nd0mize For This Useful Post:
    sepistar (5th February, 2022), zuco1989 (6th February, 2022)
  13. #3279
    Feb 2022
    I'm sorry for my bad english. I am very grateful for your help. My car has no start-stop. I'm sorry I forgot to say this.
  14. #3280
    Jul 2010
    THks,
    car has tpms
    but coding work also
  15. The Following User Says Thank You to sepistar For This Useful Post:
    r4nd0mize (6th February, 2022)
  16. #3281
    Apr 2021
    THks,
    car has tpms
    Sure accepted, but the TPMS does not work now. I sent you the coding with TPMS on via PM. So decide yourself what you want. But without TPMS the reset button has no feature anymore
  17. #3282
    Apr 2021
    It's just fine. As I said, you request all in all was very good. Start stop was not very common in this vehicles back in the days so chance was high I am correct turning it off So then you can use the coding I gave you above. But once again, after it's written to the unit, to the basic settings and then check if the wheel speed sensor direction is correct in measurements when you are driving. Cause that will cause problems if it is the other way round when driving.
  18. The Following User Says Thank You to r4nd0mize For This Useful Post:
  19. #3283
    Feb 2022
    France
    Could you provide me some help for long coding. Here the car details.
    1. 1K0907379CC
    2. WVWZZZ1KZ6P016813
    3. Golf MK5 GTI
    4. LHD
    5. 2.0 TFSI AXX engine (147Kw). DSG gearbox
    6. Front Wheel Drive
    7. No start/stop installed
    8. indirect TPMS
    9. ESP OFF button
    10. No "Hill hold" function
    11. 312 mm front discs / 288mm rear discs.
    The old MK60 block fitted on the car was 1K0907379Q
    Thanks a lot for your time.
  20. The Following User Says Thank You to Murderous972 For This Useful Post:
  21. #3284
    Apr 2021
    Quote Originally Posted by Murderous972 View Post
    1. 1K0907379CC
    3. Golf MK5 GTI
    4. LHD
    8. indirect TPMS
    9. ESP OFF button
    Uff, your case is special. That CC units have an additional byte, that I did not get through yet, completely. And old block number ending with Q is not a software number. It's probably the pump number.
    Anyways, your request is really very detailed (very good) so heres your coding with the minimum accepted stuff for the last byte. And if you had a different unit mounted before without that, it in the end doesnt matter what is in there as it does not affect your car originally.
    143B600D09230000281306E5901C004134000012
    In case this is not accepted, try the last byte instead of 12 to be:
    - 02
    - 10
    - 1A
    - 22
    - 72
    These are known, valid values.
    Sorry to go this way, but as I said this software is kinda rare, and that additional byte contains some lane assist stuff and so on. But I can tell you all the rest is perfect for your car. And if accepted with one of the possibilities for the last byte and no problems appear no matter what you use as last byte, you are fine.
  22. The Following User Says Thank You to r4nd0mize For This Useful Post:
    Murderous972 (6th February, 2022)
  23. #3285
    Feb 2022
    France
    - 02
    - 10
    - 1A
    - 22
    - 72
    Hello,
    Thank for your time.
    The part number is 1K0907379Q. I just checked right now with VCDS. It"s an old MK60 block. The pump number is 1K0614517N.
    I know the CC revision is rare. I took it because i have in mind to add all these assistant stuff on my old MK5.
    Thank you again for your time! I appreciate a lot.
  24. The Following User Says Thank You to Murderous972 For This Useful Post:
