Page 88 of 854 FirstFirst ... 3878838485868788899091929398138188588 ... LastLast
Results 1,306 to 1,320 of 12803
  1. #1306
    Apr 2010
    Quote Originally Posted by rsibiza View Post
    You need an PLCC20 to DIL converter and paralel programmer...Nothing more
    Thanks, I do have PLCC20 adapter that fits ZIF socket on programmer. What is DIL? What kind of chip to select with programmer s/w? Sorry for stupid questions, just beginning to try understand flashing.
  2. #1307
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    DIL = Dual in Line (the chip has the pins on two sides e.g left and right) atb
  3. #1308
    cniky's Avatar
    Sep 2009
    Thumbs down
    Quote Originally Posted by mishu_b View Post
    Here you will find all you need to re-fresh GAL.
    the easiest way that I found
    all the best!
    Play with that, cry later. GALS are quite sensitive and must keep specific voltage for different types. 12V not work for all, also direct connection of IC in LPT is a `dream`
    Don`t recommended that , build "GalBlast" complete version, or buy an cheap universal programmer. Chinese people lunch on the market in last mounts lots of them on affordable price.
  4. #1309
    Dec 2010
    To Carlos_: do you have any antivirus software installed? Microsoft security essentials for example? If yes, disable real time checking...
    Br
  5. #1310
    Junior Member Carlos_'s Avatar
    PT
    Quote Originally Posted by SmrekcPRO View Post
    Br
    i have norton internet security, and when i first downloaded the vcds 10.6.2, it identified as a virus (or trojan, or whatever...) so i downloaded again with real time checking disabled but even so, the vcds is still not workin, i believe that norton blacklisted the file and/or the url... i'll try to download it from another computer, because i tried to unblacklist it but i couldn't find out how to do it.
    Thanks for suggestion
  6. #1311
    Jul 2009
    Land of Choice!
    Quote Originally Posted by cniky View Post
    true - about sensitivity but from experience I can tell if you have a quite stable supply voltage source no problem to program GALs.
    currently I'm using something like this: one:Agilent DC-voltage supply E3646A. 0-8V, 3A /0-20V, 1,5A. YoC: For Sale
    all the best!
  7. #1312
    Oct 2010
    Polska
    CAN SOMEONE PUT DUMPS ONLINE FOR DIFFERENT LANGUAGES AS ENGLISH, WHAT IS THE PROBLEM???
    ONE THREAD FOR ALL THAT VAG QUESTIONS = STUPID
  8. #1313
    Feb 2011
    France
    Quote Originally Posted by HSN View Post
    The last Free DUMP is the 908 English (seem to be out by a "error"), all other DUMP are not Free.. Bizness is Bizness...
  9. #1314
    Jul 2010
    Romania
    i instaled comodo firewall free and i select to block vcds.exe and now vcds can't acces the internet and my cable is secure
  10. #1315
    DK Veteran rsibiza's Avatar
    Exclamation
    There is no problem to do
    You can post all your dumps you want..french german romanian...you can all post here.
    Thx for sharing,best regards.
  11. #1316
    Nov 2009
    Ne mogu posmotretj eto predstavlenie
  12. #1317
    Feb 2011
    Has anyone looked at a 162 eeprom dump
    an knows whats bytes are different for the different language versions? Only dumps i have seen have all been English .Or
    let me know where i can find a different language dump,version 805 up preferred.
    Thankyou
  13. #1318
    Newbie s3mick's Avatar
    May 2010
    wakefield uk
    Hi all, need a little help please, been trying to reprogram my cable and think i may have blown something, the led does not work and shows as not connected to car, there is power at the solderd connection on the triac (if thats the correct term) and also at the diode, is there a fuse just before the diode that i may have blown or anywhere else i can check. Thanks for any help Mick.
  14. #1319
    Feb 2011
    Quote Originally Posted by s3mick View Post
    Can you program the FTDI chip,have you tried the work arounds for when that chip gets nuked ? Also were you programming the atmega 162 eeprom,an incorrect eeprom for the version of VCDS you are running an it will nuke the 162 eeprom an also nuke
    the FTDI chip.
  15. #1320
    May 2010
    wakefield uk
    Hi already programmed the chip once and it worked but still not activated, would only run part scan. Tried re programming again but may have shorted something, had a couple of loose wires, just wondered where to check thanks mick
