How to JTAG a DM500
  • arcy
    • Aug 2009
    Connect jtag to dm500s Rev 7
    LPT -- signal -- dream
    2 -- HALT -- R600
    3 -- TMS -- R601
    4 -- TCK -- R602
    5 -- TDI -- R603
    6 -- TDO -- ?????
    18-25 – Gnd -- Gnd
    • El_meu
      • Oct 2008
      • 8
      #497
      Maybe the pin 1 (TDO) of the jtag connector in the dreambox is wired to the other side.
      • mulja
        • Aug 2009
        I have dm500s clone i tried load new bootloader to it
        with jtag i build on MM74HC245N
        WITH jtagdm500 software everything went ok
        tuner Alps load up to 100%
        But now just green light on and i can`t get connection with DreamUP to load image
        Help any body had anything before
        • El_meu
          • Oct 2008
          • 8
          #499
          Arcy: take a look at this
          It's in french, but I think the pics talk by themselves.
          Se ya
          • confal44
            • Oct 2008
            #500
            Hello,
            It's my forum and I explain how to pick pin 1 of jtag (TDO)directly on CPU.
            Danger, it's not easy and there are two kind of PowerPC.
            I use a microscope binocular
            best regards
            bemol
            • confal44
              • Oct 2008
              #501
              No , wire to the other side , but on the cpu
              bemol
              • res
                • Sep 2009
                very useful, hope i can fix my dm500.tks!!!!
                • jdecelis
                  • Sep 2009
                  if you plug a connector instead of the serial once it won;t work?
                  • massas9
                    guys hello.Is it difficult jtaging dreambox?
                    • K_o_G
                      • Sep 2009
                      i have a blackbox dm500 and it?s dead.
                      tryed windowstool but if i get a connect after some trys the tool crashes. if i use dos tool it stops at downloading 0%
                      can someone help me?
                      ***update***
                      Windows Tool doesent work for me. Everytime i get a connect the tool crashes after a click on the write button.
                      dostool:
                      here the messages i?ve got
                      reambox Dm500 board initialize
                      Flash info. : INTEL Unknown
                      [dm500] reading CA:03 ff 07 ff 0f ff 1f ff 3f ff 7f ff ff ff 00 10
                      [CA] Ho Ho! CloneWARS corrupted bootloader eh?! consider getting a IPBOX!
                      Readed Config Area
                      Configuration Area
                      Mac Address: 00:09:34:aa:0b:cc
                      Redunderant Mac Address: aa:0b:cc
                      Tuner Type alps
                      Mac Address Change Requested
                      Commit Config Area
                      Configuration Area
                      Mac Address: 00:09:34:01:a4:3f
                      Redunderant Mac Address: 01:a4:3f
                      Tuner Type alps
                      Erase Flash done
                      Download..................................... done
                      Checking. 0% error at 0xfffe005e (0x0000, 0x0000)
                      Programming failed !
                      the download step takes a long time and i think the bootimg was not written correctly (Programming failed)
                      the green led is off after flashing (flash turn off turn on). but if i use the info option i dont get the clone message.
                      the info option says the flash is ok but still no green light.
                      can somebody help me?
                      • trickykid
                        • 89
                        #506
                        excuse mu ignorance, but exactly is jtag? and what does it do to the dreambox?
                        • brams
                          • Sep 2009
                          It's a special cable that allows a PC to try and recover a Dreambok with a nuked bootloader.
                          • MastaG
                            • 6
                            #508
                            Can someone provide me a blimg for 500c with NXP tuner?
                            • ivanfed
                              • 4
                              #509
                              I fixed my DM500s today. When I use Dos version, it was staying on Erase flash done. So I use Windows version.
                              1. Unplug the box
                              2. Keep pressing on Connect and plug and unplug your box until Write comes up.
                              Just don’t press connect after box was connected.
                              • widar
                                nearly crazy
                                I will go crazy, after a lot of attempts with the Windows version, I ones had it run under the Dos version, all the way
                                to 100% complete, but no light or contact, when I try to load a img with serial cable, so I start to try to flash it again
                                if it still was something wrong, as my dos skills is not that good. Do I have to unsolder the J-tag before it works, or is it
                                possible to keep it until I know that the box is OK. Did I use
                                wrong bootloader? I did not have any choises, the default
                                was used, I think. Any help, or advices is welcome, thanks
