How to JTAG a DM500
I have dm500s clone i tried load new bootloader to it
with jtag i build on MM74HC245N
WITH jtagdm500 software everything went ok
tuner Alps load up to 100%
But now just green light on and i can`t get connection with DreamUP to load image
Help any body had anything before
i have a blackbox dm500 and it?s dead.
tryed windowstool but if i get a connect after some trys the tool crashes. if i use dos tool it stops at downloading 0%
can someone help me?
***update***
Windows Tool doesent work for me. Everytime i get a connect the tool crashes after a click on the write button.
dostool:
here the messages i?ve got
reambox Dm500 board initialize
Flash info. : INTEL Unknown
[dm500] reading CA:03 ff 07 ff 0f ff 1f ff 3f ff 7f ff ff ff 00 10
[CA] Ho Ho! CloneWARS corrupted bootloader eh?! consider getting a IPBOX!
Readed Config Area
Configuration Area
Mac Address: 00:09:34:aa:0b:cc
Redunderant Mac Address: aa:0b:cc
Tuner Type alps
Mac Address Change Requested
Commit Config Area
Configuration Area
Mac Address: 00:09:34:01:a4:3f
Redunderant Mac Address: 01:a4:3f
Tuner Type alps
Erase Flash done
Download..................................... done
Checking. 0% error at 0xfffe005e (0x0000, 0x0000)
Programming failed !
the download step takes a long time and i think the bootimg was not written correctly (Programming failed)
the green led is off after flashing (flash turn off turn on). but if i use the info option i dont get the clone message.
the info option says the flash is ok but still no green light.
can somebody help me?Last edited by K_o_G; 25 September, 2009, 12:25.Comment
nearly crazy
I will go crazy, after a lot of attempts with the Windows version, I ones had it run under the Dos version, all the way
to 100% complete, but no light or contact, when I try to load a img with serial cable, so I start to try to flash it again
if it still was something wrong, as my dos skills is not that good. Do I have to unsolder the J-tag before it works, or is it
possible to keep it until I know that the box is OK. Did I use
wrong bootloader? I did not have any choises, the default
was used, I think. Any help, or advices is welcome, thanksComment
