Recording freeze after sometime in dm800hd se
  • Moksan22
    • Jul 2012
    • 19
    I just installed an internal hdd toshiba 500gb 5400rpm.recording seems to be no issue til after about 50mins when the screen and recording freeze.afterthat I had to reboot my box to get it working again.any idea what's the problem"?
  • edlimym
    • Feb 2012
    • 29
    could you check your box info and see if the -
    Front Processor is Version 1 or 3.
    Ver 3 got this timer recording issue. Ver 1 is ok so far. I have a Ver 3 800hd se and after 40 - 50 mins, the system clock froze and recording stops. must reboot the box. timer recording is pain in the ass.
    • ypvs125
      • Dec 2010
      • 506
      If u really need to use timer recording, the only method that i found to work is to install time update plugin and the box need to be connected to internet.
      • Moksan22
        • Jul 2012
        • 19
        My front processor is version 1 but still have this issue.where is this time update plugin? Cannot find under the downloads list in dreambox.need help.also do u guys know how to use external usb drive to record.I tried but Iggy crash my system.also it seems to save the recorded file in the flash memory space instead of the external usb folder.no problem recording in my internal hdd other then the freeze.
        • ypvs125
          • Dec 2010
          • 506
          Many reported issues with the clock with front processor version 3. What image r u using? Try reflashing a different image to see if it solve the clock issue.
          • uu161
            • May 2012
            • 372
            the freeze happen on recording HD or SD?
            i think mine only happen on rec HD but not sd will check and update again
            if you like the post use the Like button located bottom right corner of each post
            if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
            • ypvs125
              • Dec 2010
              • 506
              Those with front processor 3 will be having difficulty doing either timer recording or normal recording as the box may lose time out of sudden and thus lead to freezing of the hdd.
              • Moksan22
                • Jul 2012
                • 19
                I think mine too only have issue recording HD channels.SD so far no problem.not sure why.
                • uu161
                  • May 2012
                  • 372
                  Version 1 don't why also if i didn't remember wrong
                  when i just got it brand new no issue duno what i do on it
                  noted but then shall try the Gp2 Dvtime?
                  • ypvs125
                    • Dec 2010
                    • 506
                    So yours is which version? There is no fixed solution to this but to send it back to yr supplier for exchange.
                    • uu161
                      • May 2012
                      • 372
                      mine are ver 1
                      will try to find out wrong with it
                      anyway i plan to change the tuner card also
                      • uu161
                        • May 2012
                        • 372
                        Small update: good news is that I guess I found the problem more detail late night when I back home to double confrim. Finger cross hope it still recordings since i start recording last night till is morning and morning to now still unknown yet.
                        • Moksan22
                          • Jul 2012
                          • 19
                          what's the problem bro
                          • uu161
                            • May 2012
                            • 372
                            i think something to do with mount hdd part and maybe also the recording path etc.
                            still not 100% confrim but got 80%.
                            am still playing with it getting better and better
                            • uu161
                              • May 2012
                              • 372
                              recording freeze mine had fixed
                              internal hdd installed
                              am now using Cnigma-OpenPli 2.1-dm800se-ssl84b.nfi
                              before also have a problem on the above images.
                              this is what i done
                              1) flash BlackHole-1-7-0-dm800se-ramiMAHER
                              2) initialize hdd and mount ( which i find blackhole initiallze the old ver much stable ) for mount /media/hdd
                              after tested path all working. BlackHole-1-7-0 don't come with cams if u want install ur own and setting and key etc
                              3) now reflash to Cnigma-OpenPli 2.1-dm800se-ssl84b.nfi
                              4) it will automount without need to do any thing on initialize hdd and mount again path will be all set and u are ready to go
                              this work for me
                              don't blame me if it do not work for you.
                              1 more thing i had done update the TS Panel 6.1
                              the above tested
                              800se 210 sim
                              front processor ver 1.0
                              2.5 hdd 500gb 5400rpm
                              time recording
                              full day recording
