Recording freeze after sometime in dm800hd se
Did you try streaming via openwebif for certain duration before? Mine one will freeze after streaming like 40 min. At first suspect is hardware issue but after exchanged the box the issue remain.Comment
small update:
i got small good news
today tested using (NAS) network mount to rec from 2 plus till now 10:24 ( about 8 hrs rec ) no freeeze
another update
check pics 13hr rec no freezeAttached FilesLast edited by uu161; 26 January, 2013, 07:57.if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
Hi,
Having similar timer recording issues on DM800HD PVR running SG Newnigma2 v3.3.2. USB HDD would freeze sometimes at 20+ or 40-50m. Tried reformatting etc. Also Media player did not recognized recorded files. Can only play from File Explorer.
Just reflashed image, and also using formatted NTFS. Allow automount. Let's see if this works for tonight timer record.
Could someone advise me how to check processor rev?
Thanks.Comment
There is something like About screen on the setting have the processor rev.Hi,
Thanks.Comment
The power from the dm800hd usb may not be enough to drive the hdd and for playback, press the pvr button. As for processor rev, only dm800se is applicable.Hi,
Thanks.Comment
i am also having the same problme with the box hanging after a while for recording timer. I am not using the cnigma but the ramihd newnigma 3.3.2. I have the 800hdse ...
note for me i am recording to a local HDD in the dreambox itself (not NAS)Comment
It is not the image faulty as tried with various images but still recording freezes. Most likely box with fp3 would have problems doing recording.Comment
I use 2.5 internal sata HDD,.very stable no problem. The recorded file is under Ts format. Use vlc player to view On your pc.Comment
i am actually on front processor v1 and having the problem.
The dreambox timer is not the problem because i never see any delay between actual time. they are always the sameComment
